Will Magnum front axle shaft fit in a 5488?
Joninva
5488 sn 4396. I need to replace the right axle shaft and Sun shaft. Splines worn on outer shaft, u joint cups loose in shaft and yoke. If I can get a complete shaft from a 71 or 72 series Magnum cheaper, would it fit? The 88 & Magnum sun shaft is the same part #.
Is there a cheaper way to get genuine Dana axle parts, other than going through CNH? How good are the aftermarket parts out there ( A&I, Hy Capacity, etc )
