dads706 894 Posted November 6, 2020 Share Posted November 6, 2020 I try to keep a 55 gallon drum of kerosene on hand to use in the Knipco heater. Went to my supplier the other day and almost had to take out a loan when they handed me the bill. Does anyone use diesel in theirs? Or maybe a mix? Kero is much cleaner, but whoo hooo, kinda expensive. Quote Link to post Share on other sites
lightninboy 447 Posted November 6, 2020 Share Posted November 6, 2020 I doubt we've used our Knipco for nine years or so. I don't think we bought kerosene for it, so I guess it's got diesel fuel in it. Winter mix I suppose. Quote Link to post Share on other sites
Wi Ih 848 Posted November 6, 2020 Share Posted November 6, 2020 Diesel works fine but it definitely does make more smoke. I used number two though 1 Quote Link to post Share on other sites
Edsfarms 85 Posted November 6, 2020 Share Posted November 6, 2020 If you got a medium size airport near by you could go to the FBO ( Fixed base operator)i.e. airport gas station. and purchase some Aircraft turbine engine fuel. "Jet A" Pretty close to Kerosene. I'm thinking it in the $2-7 dollar range depending on where you live. https://www.airnav.com/fuel/report.html Quote Link to post Share on other sites
IH Forever 373 Posted November 6, 2020 Share Posted November 6, 2020 We have a Hotsy at work that gets used a lot every day washing trucks. They burn No. 1. Ours is pulled outside in front of shop doors. With a Knipco in doors you’d probably have more odor. Quote Link to post Share on other sites
cobfly 1,244 Posted November 6, 2020 Share Posted November 6, 2020 Use #1. Quote Link to post Share on other sites
560Dennis 1,396 Posted November 6, 2020 Share Posted November 6, 2020 I think kerosene was $3.57 a gallon last time I got it. Fordson runs on kerosene . But think I’ll stick to gasoline . Quote Link to post Share on other sites
DaveinSD 138 Posted November 6, 2020 Share Posted November 6, 2020 I’ve always used diesel in mine. Kerosene is hard to come by around here and is super expensive, plus I always have diesel on hand..... Quote Link to post Share on other sites
TP from Central PA 3,163 Posted November 6, 2020 Share Posted November 6, 2020 Use diesel in mine..............well, until that will be unobtainium soon. Quote Link to post Share on other sites
Wes806 1,479 Posted November 7, 2020 Share Posted November 7, 2020 Use diesel in mine. As said little more order and smoke which doesn't bother me as I keep a window or 2 open when I'm useing it. I use the fuel as I get at the pumps for trucks as there is place for me to get off-road in town. 25 miles to place for off-road. ( one way ) Quote Link to post Share on other sites
vtfireman85 5,039 Posted November 7, 2020 Share Posted November 7, 2020 I used to use off road in the salamander, smoked pretty bad.. but it was what was there i’m alright..really 🤪 Quote Link to post Share on other sites
catman13 28 Posted November 7, 2020 Share Posted November 7, 2020 If you got a medium size airport near by you talk to a mechanics and see if you can get the jp4 they drain out of the plane fuel tanks, years ago i got 4 55 gal drums of it for free because they have to get rid of some how Quote Link to post Share on other sites
smfarms 73 Posted November 7, 2020 Share Posted November 7, 2020 I burn used jet fuel. Really clean and low oder. My son is a helicopter mechanic and is always looking for a place to get rid of drained fuel. Apparently if it is drained it cannot be reused. Diesel is not as bad today because of sulfur removal Quote Link to post Share on other sites
iowaboy1965 2,338 Posted November 7, 2020 Share Posted November 7, 2020 Dad always used diesel and so do I, what little I run a torpedo heater. Quote Link to post Share on other sites
New Englander 1,486 Posted November 7, 2020 Share Posted November 7, 2020 It's unlikely that you'll find any JP4 anywhere but foreign countries using very old jets. JP4 is 50/50 kerosene/gasoline and was used in early jets with no fuel heaters, usually oil/fuel heat exchangers. The US military now uses JP8 which is the same as civil JetA1, which is the same as Jet A with prist, an anti ice additive premixed in. I used to fly for a defense contractor and we visited many AF bases where we got cheap JP4. The problem with it is it's so light range is compromised. There's much less energy in it than Jet A. That was in the '80s but Uncle Sam doesn't have anything that needs it anymore. Navy uses JP5, a higher flash point fuel for the carrier based planes. At civil airports the military planes will just order Jet A1 or Jet A with Prist. Anyway, all of the above may just be interesting. Jet fuel is way cleaner than heating oil and diesel and is good to burn in salamanders and the like. Company I worked for had to dig up all the underground storage tanks and didn't bother to install a new above ground tank for the hangar heaters, just jet fuel. They tapped off the jet tank for the heaters and ran it through a meter to not pay airport flowage fees on it. Servicemen would show up to replace the filters on the heaters and say someone just changed them! No, jet fuel is just that clean. One funny story about the fuel drained from aircraft sumps and what to do with it: As was stated above, the fuel drained doesn't go back into the tanks but has to be disposed of. One mechanic I knew heated his house on it. Another, a very good friend of mine, was draining sumps on his company's jet and the drain barrel was full. His chief pilot, a real pompous A, had just bought a diesel Rabbit so he poured it in the tank. Pompous started claiming the Rabbit was getting better mileage as it broke in, so Charlie started making it a habit of pouring fuel into it. Well, the rabbit was getting better and better mileage now nearly 90 MPG! Pompous A was bragging about it to anyone who was near. The disposal company finally showed up and drained the sump disposal barrel and the additional fuel suddenly stopped. Mr. chief pilot took the Rabbit into VW and started to complain that something had gone wrong as the car had been getting 80 plus MPG and now was only getting 40+. My buddy had great fun with that one. 2 Quote Link to post Share on other sites
1586 Jeff 1,425 Posted November 7, 2020 Share Posted November 7, 2020 17 hours ago, vtfireman85 said: i’m alright..really 🤪 We know you too well........ Quote Link to post Share on other sites
1586 Jeff 1,425 Posted November 7, 2020 Share Posted November 7, 2020 6 hours ago, New Englander said: Another, a very good friend of mine, was draining sumps on his company's jet and the drain barrel was full. His chief pilot, a real pompous A, had just bought a diesel Rabbit so he poured it in the tank. Pompous started claiming the Rabbit was getting better mileage as it broke in, so Charlie started making it a habit of pouring fuel into it. Well, the rabbit was getting better and better mileage now nearly 90 MPG! Pompous A was bragging about it to anyone who was near. The disposal company finally showed up and drained the sump disposal barrel and the additional fuel suddenly stopped. Mr. chief pilot took the Rabbit into VW and started to complain that something had gone wrong as the car had been getting 80 plus MPG and now was only getting 40+. My buddy had great fun with that one. Now that is an AWESOME prank to play on someone!!! Which was greater? The diagnostic bill(s) at Volkswagen or the fuel savings? 1 Quote Link to post Share on other sites
