Case IH 5200 series axle stops when attaching loader
Snowmad
I'm going to mount a CIH 510 loader on my CIH 5230.  In loader operators manual, it says since I have 14.9R24 tires on the front, I will need Oscillation Stops.  Does anyone know what these are or where they would mount?  There's a small hole in the loader mount and in the tractor frame that I'm guessing it attaches to.  Any idea what it would be listed under on CIH parts?  I've been looking for it but to no avail under tractor or loader.  Not sure how critical it is, I don't want to mess anything up.  Thanks for any pictures/advise/description of these stops.
Bolt up on bottom of front bolster. Axle pivots up against them. Pull up on a bank and see if wheel contacts frame thru complete turning range. if not do nothing.
On 11/1/2020 at 8:46 PM, striker782 said:
Striker, I thought it might be that.  I was looking on the CIH site and it's a number that isn't listed (no longer available).  I tried your diagram too and same thing.  Guess I'll have to try to make something if I need them.  Thank you.
