I tore down my clutches about 15 years ago. I cleaned the all the discs the best I could and replaced some. The both sides were stuck again even with the handles tied back. I got the right side to break free but not the left. I'm wondering if putting all new discs in if it would be better and last longer. With one still working its probably not worth tearing down for the little I use it but may have to eventually.  I do live in a damp climate and have had problems with other clutches. I dread tearing it down again.
 I know some machines have clutch housings that can be filled up with some penetrating oil.
 I had good luck filling an ac hd6 with diesel and tied back the handles, went to work with the blade on a big stump, the disks broke free after a while.
Have to watch your solvent choice doesn’t disintegrate the frictions or also leave an oily residue behind, for IH they recommended stoddard solvent which today is varsol  I believe, may as well work it does it have a dozer on it? If so get some heat into it with the brake and cozy up to a big stump and try and pop that side free
They do have bimetallic available new that are not as prone to sticking
I used diesel the first time with no luck. I pushed a few stumps out yesterday with no luck. I think I have the lever adjusted up so tight that its released. Pretty sure the only way is to tear it down. I was pricing discs and that's not a option right now anyway. I may try hooking onto a bigger stump but have been down this road before and doubt it will help. Thanks for the suggestions.
I have tried diesel before but didnt have any luck. Wouldnt hurt to get something in there anyway. Especially the side tgats free.
That era were all designed as dry clutches for that application, diesel can leave an oily residue if that side is free I would leave it be as it could slip, swell or disintegrate it’s the other side that’s the problem
I got it free today but the last 3 times I used it I had to break it free. If it's more than a few months it will likely be stuck again.😭
For that I would play with your steering clutch lever on the right side and get against something will good resistance and try to get it at the point of engage/disengagement to polish the surfaces as they wear against each other
Thanks. Good idea. I did work it for a few hours after I broke it free. Debating whether or not to tear it down now or wait until both sides are stuck.
Your call it’s a crappy job but if the money tree isn’t bearing fruit may as well wait or try and use it more frequently, definitely not ideal but can mostly maneuver with one side working
I would try the bimetallic for your climate for the extra $$$ it could be worth it in the long run
Be nice to hear from others if that solved that issue
The only thing good about doing it now is I can get it in the shed easier. Probably wait though as little as I use it. To many other projects I'm not getting done either. Thanks for the suggestions. Maybe I will look into mineral spirits. That seems to be what varsol and stoddard are basically.
1 hour ago, Rawleigh99 said:
I am thinking about trying vinegar in the steering clutch on an AC HD9 I just acquired.  It will remove rust from tools, so it might work in that.  Anyone see any harm in trying that?
No idea. I would think it would need to be flushed out good afterwards.
   Ahh     Rawleigh..........gone over to the dark side,  eh ??!!!!
....as Hardtail said....''it's the other side that is the problem''.......and the last set of steering clutches  that I pulled apart......on a Mate's      BTD6, were rust pitted, (the steel plates were.., obviously...)....so I spent hours cleaning them up, to remove all the rust ...tried to ''de rust '  the millions of little  pits...put gunk on them to 'kill''  the remainder etc...put it all back ....everything  functioned as it should......even the missing skin on my hands healed up fine.....
...but....my Mate wanted to paint the crawler...so it was soda   blasted..  primed etc...taken back to his place on the big dairy farm...left for months ....finished painted top caot  in the summer..left through the next winter, because there is so much other work going on......then, when he finally got to use it...guess what...clutches frozen again.....sigh
....and so badly frozen, that the tree  stump approach didn't work.......and I have three  IH's in similar state here...only the old D6B    never bothers me in the clutch dept....and that is because of its frequent use....and I am off 'bush and bog ''   discing this morning......and that is one job when you hear the clutches    ''squeal ''  .....which tells you they  are dry as Sam Corks rectal orifice......thus   they never seem to get ''frozed up ''
So that is the big issue with infrequent   use of these old tractors.........and the small ones are such a bloody pain to work on......so Rawleigh, I doubt that any ''liquid stuff ''  would help...I filled the TD6  left side compartment full of diesel  ...left it for two weeks.... all it achieved was making a miserable bloody job, even more miserable with the stench of diesel and the oily residue left behind.......
If I remember right on mine it cant be filled full enough to submerge clutch pack. I would think it would have to be ran alot to get it circulated around?
...correct.....plus the obvious issue...if the clutch pack is so 'frozen up ''.....the 'fluid'...whatever it may be......is never going to get where it is needed, anyway.......
I tried everything to get them free the first time. Could've saved a bunch of money and time by just tearing it down.
