sandhiller 14,789 Posted October 15, 2020 Share Posted October 15, 2020 1989 Ford F350. 7.3D The fitting is plastic and seems pretty soft. Put a half inch wrench on the flats and it doesn't want to turn out. I do not want to bugger it up as it is running now. Fuel leak is bad juju and needs repaired Any education will be appreciated Quote Link to post Share on other sites
Dasnake 2,825 Posted October 15, 2020 Share Posted October 15, 2020 3 minutes ago, sandhiller said: 1989 Ford F350. 7.3D The fitting is plastic and seems pretty soft. Put a half inch wrench on the flats and it doesn't want to turn out. I do not want to bugger it up as it is running now. Fuel leak is bad juju and needs repaired Any education will be appreciated Is it like our dodges, rubber gasket between the bowl and the top? It looks like slow weeping what about a new filter and reapplying the bowl. 1 Quote Link to post Share on other sites
sandhiller 14,789 Posted October 15, 2020 Author Share Posted October 15, 2020 1 minute ago, Dasnake said: Is it like our dodges, rubber gasket between the bowl and the top? It looks like slow weeping what about a new filter and reapplying the bowl. Nope, spin on filter and it is coming out of that fitting on top ( fuel filter heater maybe?) But thanks for playin'😃 Shoulda drawed the arrow thingy pointing to the leaking offender but trying to get ready for Fire Mtg................ Quote Link to post Share on other sites
Ihfan4life 3,094 Posted October 15, 2020 Share Posted October 15, 2020 What about sticking a flat blade screwdriver into it and turn it out? 1 Quote Link to post Share on other sites
sandhiller 14,789 Posted October 15, 2020 Author Share Posted October 15, 2020 2 minutes ago, Ihfan4life said: What about sticking a flat blade screwdriver into it and turn it out? The electric spade in the middle would probably break off. But I could try to find a screwdriver that might fit. If it is a fuel heater it would not be missed that much as it doesn't driven in winter that much. Want to do it right the first time as C4 needs to be up and ready to go at a moments notice. Can't risk it being down to a screwup on my part. 1 Quote Link to post Share on other sites
hardtail 536 Posted October 15, 2020 Share Posted October 15, 2020 Might be a water sensor? Wonder what the chance it has NPT threads and you could plug it off? Have you tried YouTube? 1 Quote Link to post Share on other sites
Dasnake 2,825 Posted October 15, 2020 Share Posted October 15, 2020 41 minutes ago, sandhiller said: Nope, spin on filter and it is coming out of that fitting on top ( fuel filter heater maybe?) But thanks for playin'😃 Shoulda drawed the arrow thingy pointing to the leaking offender but trying to get ready for Fire Mtg................ Ohhh, well then Alex, I’ll take “I dunno” for 300.00....... 1 Quote Link to post Share on other sites
1958560 91 Posted October 15, 2020 Share Posted October 15, 2020 We have popped it out after filter is removed then tapped hole with 1/2" pipe thread tap and install plug from the bottom, as long as you dont need the heater. A little hard to keep tap straight and square in hole from bottom going up but can be done. 1 Quote Link to post Share on other sites
sandhiller 14,789 Posted October 16, 2020 Author Share Posted October 16, 2020 6 hours ago, hardtail said: Might be a water sensor? Wonder what the chance it has NPT threads and you could plug it off? Have you tried YouTube? Thinking water sensor would be on bottom like my Cummins but with spin on filter that is not an option. Water in fuel seems logical. Hoping to hear from someone who has had this problem before and had a fix. Havent tried youtube. Just hit submit reply with the "red arrow" post when fire page went off. Close and a good grass fire so made it home in time to make monthly mtg. Need to research more. It is running so will not mess with it until I know for sure what I am doing. Red flag conditions every day so cannot afford to be down for a minute, 5 hours ago, 1958560 said: We have popped it out after filter is removed then tapped hole with 1/2" pipe thread tap and install plug from the bottom, as long as you dont need the heater. A little hard to keep tap straight and square in hole from bottom going up but can be done. So, it is a push in??? Thought maybe jam nut up from bottom. If I need to tap and plug that would be ok. Just need to be sure it is a quick and successful fix before I attempt it. With my luck page would go off half way through procedure. HOping it will last until we get some moisture and fire conditions improve. Quote Link to post Share on other sites
jass1660 1,962 Posted October 16, 2020 Share Posted October 16, 2020 Always need the heater in there as wax develops from the fuel regardless of temperature. 2 Quote Link to post Share on other sites
Dasnake 2,825 Posted October 16, 2020 Share Posted October 16, 2020 12 minutes ago, jass1660 said: Always need the heater in there as wax develops from the fuel regardless of temperature. If there isn't a heater how would this wax disappear on a dodge? Do fass systems remove this wax? My fass system has a port to install a heater but in our climate is that need? Thanx. Quote Link to post Share on other sites
sandhiller 14,789 Posted October 16, 2020 Author Share Posted October 16, 2020 10 minutes ago, jass1660 said: Always need the heater in there as wax develops from the fuel regardless of temperature. True and good point, really would like to fix it right. Can't afford to plug a filter at a critical time. It seems strange to most but am thinking about switching out my wildland gear for bunker gear in the truck. Hard to believe you can get cold fighting a grass fire, but this time of year it happens. Mopping up this afternoon it was damn chilly. But, yeah, I agree, need to keep the htr operational. So, could it push in from the top and be held in place by a nut on the underside of the housing top??? Wouldn't take that long to spin filter off, just like to know ahead of time what to expect Quote Link to post Share on other sites
sandhiller 14,789 Posted October 16, 2020 Author Share Posted October 16, 2020 2 minutes ago, Dasnake said: If there isn't a heater how would this wax disappear on a dodge? Do fass systems remove this wax? My fass system has a port to install a heater but in our climate is that need? Thanx. There is a heater on a Dodge OEM filter housing, at least my Gen II anyway Not sure about the Fass 1 Quote Link to post Share on other sites
Dasnake 2,825 Posted October 16, 2020 Share Posted October 16, 2020 32 minutes ago, sandhiller said: There is a heater on a Dodge OEM filter housing, at least my Gen II anyway Not sure about the Fass I did the delete, I'll check later on, good to know with winter comin on. Quote Link to post Share on other sites
jass1660 1,962 Posted October 16, 2020 Share Posted October 16, 2020 I’d just replace the whole head unit. Thousands of those trucks around Rock Auto probably has one. 1 Quote Link to post Share on other sites
WishIhada1466 713 Posted October 16, 2020 Share Posted October 16, 2020 Here is info I found on a ford truck site. Once the filter adapter is removed........right hand thread. The heater comes out as a whole but has two halves. Remove the complete stainless and plastic parts by pushing down (in) on the neck part that protrudes from the filter header. You will now see a shiny stainless half and a plastic half, you will be able take the two halves apart carefully. There is a stainless spade connector protruding through the plastic neck. This is the connector to the heater wire on the top side of the filter header. On the spade connector there is a (locking tab) small piece that is bent out to secure it in place. Squeeze this piece straight and push the spade down through the neck. The stainless spade body part should seperate from the plastic portion of the assy to reveal a second o-ring. This oring causes the seal from the spade body to the inside of the plastic neck. 1 Quote Link to post Share on other sites
Diesel Doctor 2,091 Posted October 16, 2020 Share Posted October 16, 2020 It is the F2tz9b249a Fuel Filter Housing Heater Element 9J294 for Ford 7.3L IDI Diesel It is installed coming up from the bottom. See it here. https://www.ebay.com/itm/F2tz9b249a-Fuel-Filter-Housing-Heater-Element-9J294-for-Ford-7-3L-IDI-Diesel/203037829798?epid=8033610807&hash=item2f45ff6aa6%3Ag%3AzUUAAOSw9EtefqNM&fits=Year%3A1989|Model%3AF-250|Make%3AFord 1 Quote Link to post Share on other sites
sandhiller 14,789 Posted October 16, 2020 Author Share Posted October 16, 2020 2 hours ago, WishIhada1466 said: Remove the complete stainless and plastic parts by pushing down (in) on the neck part that protrudes from the filter header. 2 hours ago, Diesel Doctor said: It is installed coming up from the bottom. That is what I needed to know Oring is leaking, might test to see if heater is still good, if not the one on Ebay is not too much. Might even check with Rock Auto as jass suggested Thanks Christian and DD Quote Link to post Share on other sites
edwardporter1 227 Posted October 16, 2020 Share Posted October 16, 2020 had a hairline crack in housing. would lose prime on a 94 7.3 diesel. replaced housing then good to go 1 Quote Link to post Share on other sites
Tmtbob 577 Posted October 16, 2020 Share Posted October 16, 2020 Google the filter number for a head unit for it. Your local Napa might even have that in stock. Or if they are any good they could order one in from the filter number without the heater. Hope you can get it fixed fast and easy without a page 1 Quote Link to post Share on other sites
sandhiller 14,789 Posted October 16, 2020 Author Share Posted October 16, 2020 8 minutes ago, edwardporter1 said: had a hairline crack in housing. would lose prime on a 94 7.3 diesel. replaced housing then good to go This has always been a hard starting pig. Thinking air was coming in here before (when it sat), now bad enough that fuel is going out. (when running) Quote Link to post Share on other sites
1958560 91 Posted October 16, 2020 Share Posted October 16, 2020 If I remember right, remove filter and then remove the adapter nut that filter screws onto. Then push it thru the housing. We're up in SD and haven't had trouble without the heater during winter, just run #1 during coldest months 1 Quote Link to post Share on other sites
jass1660 1,962 Posted October 16, 2020 Share Posted October 16, 2020 The heater isn’t for heating the fuel the truck Has to start before it would even start the element warming up. If it was for heating the fuel it would be in the tank It’s in the filter to try to keep the moisture from accumulating 1 Quote Link to post Share on other sites
Sledgehammer 7,444 Posted October 16, 2020 Share Posted October 16, 2020 Yup, Fuel filter heater connector. Keeps fuel from gelling. You can tap the hole to 1/2” and put a brass pipe plug in it according to my diesel mechanic buddy who has a couple IDI 7.3 trucks. He says it probably hasn’t worked in a long time knowing those things. 1 Quote Link to post Share on other sites
