Need Help identifying model and year.
What is the number on the block by the oil filter ?  Part number of block
also over mag ?  C113 oR C123
14 hours ago, John Rowehl said:
Serial no. Info on tractordata.com would confirm it was made in late 1949.  It does also suggest that a Super A would have hydraulics. Maybe it was an option.
Thanks.I might look at installing some kind of hydralic system . Most likely aftermarket, I'm switching to 12 volt.
Just notice is there a dust cover below the magneto? Or is it block casting?
  • 3 weeks later...
Should be date code tag on engine block in behind your magneto. Two numbers and a letter.
First number is month , second is day, letter corresponds to year.
These should be years that a straight A or Super A could have been built:
I - '39
J - '40
K - '41
L - '42
M - '43
N - '44
O - '45
P - '46
Q - '47
R - '48
S - '49
T - '50
U and W - '51 (note the letter "V" was skipped)
X - '52
Y - '53
Z - '54
There will be other tags on the tractor if you look close, (location vary's depending on model i'm pretty sure) my uncle's H has a L stamped '42 rear end but the engine is stamped R for '48, so some previous owner did a swap, so compare a few tags just in case of that.
Hope this helps, enjoy the Farmall.
