806 leaking oil front bolster
dhanraha
More than likely it is a steel line or banjo fitting.  Pull the radiator to confirm. If it is a leak on the square plate, it may just be the first o-ring behind it.  You need to be certain of where it is coming from.  Rebuilding a bolster is not easy.
