IH part
R Pope
My 806 has a couple of these in the tool box......."Screw-#385784R11".  It is a fine thread stud with a nut on it, 5 1/2" long and about 7/8' diameter, as close as I can measure through the thick plastic bags they are in. Anybody know what they are for? They are in CNH bags so are newer than the 806.
Those are replacement bolts for the rear wheel clamp that goes around the axle.  If you are planning on running clamp on duals you will need them as those bolts will break from the added stress.
