rodhergott 0 Posted October 2, 2020 Share Posted October 2, 2020 Not looking forward to removing these as they leak really badly. A friend told me that u can buy graphite packing cord and just loosen the cap; put this stuff around the ram and tighten the cap back on. Anyone heard of this and if you have where do I get the packing cord from? Quote Link to post Share on other sites
oldiron29 12 Posted October 2, 2020 Share Posted October 2, 2020 he is right that is how it is done. Mcmaster Carr has graphite packing in all size's Quote Link to post Share on other sites
rodhergott 0 Posted October 3, 2020 Author Share Posted October 3, 2020 I’ll take it apart tomorrow. See what I find Quote Link to post Share on other sites
rodhergott 0 Posted October 5, 2020 Author Share Posted October 5, 2020 Anyone have suggestions for what size to order for 1949 Quote Link to post Share on other sites
oldiron29 12 Posted October 5, 2020 Share Posted October 5, 2020 If you took the cap off and slide it up the shaft some you can see the gap between the shaft and the retainer so that is the size packing you need. not sure 3/8" or 1/2" you wrap it around as many times as you can and keep pushing it down till you can't fit anymore, Hence PACKING. Quote Link to post Share on other sites
rodhergott 0 Posted October 5, 2020 Author Share Posted October 5, 2020 I took the cap off and yes I can measure. I suppose I could measure the old stuff I took out. Your explanation is very helpful. Thanks Quote Link to post Share on other sites
Rawleigh99 826 Posted October 11, 2020 Share Posted October 11, 2020 On boat stuffing boxes you cut rings that fit around the shafts snugly. You don't coil it. I don't know if those on hydraulic cylinders are different, but on boats you offset the cuts like you do with piston rings and lay them in one on top of the other. Boat places also have the graphite braided packing. Quote Link to post Share on other sites
rodhergott 0 Posted October 11, 2020 Author Share Posted October 11, 2020 I’ve been thinking about that and concluded that cutting rings rather than coiling makes more sense. Just an update for everyone that helped upon taking apart I found both packing and vseals. Ive ordered packing but I’m also trying split rubber v seals. I think a problem with the old is that there wasn’t enough seal/packing in there. If I was starting from scratch I’d just put in more packing Quote Link to post Share on other sites
hardtail 534 Posted October 11, 2020 Share Posted October 11, 2020 All the valves and pumps we would cut the rings but for this I just think coiling it in there would work Quote Link to post Share on other sites
Kevingweq 180 Posted October 12, 2020 Share Posted October 12, 2020 Had a debate on coiling vs packing on another forum ,,, apparently some older manuals on waterpump packing speced rings and other manuals left it coiled (but trimmed so that end of packing was flattish.). 6 of 1 half dozen other 😀 Quote Link to post Share on other sites
rodhergott 0 Posted October 12, 2020 Author Share Posted October 12, 2020 I wondered f getting the coiling to end at the same point it started would also be a good idea Quote Link to post Share on other sites
north of 60 191 Posted October 13, 2020 Share Posted October 13, 2020 On 10/11/2020 at 7:51 AM, rodhergott said: I’ve been thinking about that and concluded that cutting rings rather than coiling makes more sense. Just an update for everyone that helped upon taking apart I found both packing and vseals. Ive ordered packing but I’m also trying split rubber v seals. I think a problem with the old is that there wasn’t enough seal/packing in there. If I was starting from scratch I’d just put in more packing Would you be able to share a few pictures of your project and your progress.... for those of us who have not been into these cylinders yet, but may have to or should ? Quote Link to post Share on other sites
