1660 transmission
on my 1660 combine the transmission it will not shift in to third gear there is a cable that runs down to it not sure how it all works is there supposed to be a spring to pull the bracket down to slide it in third not sure how this works
there is a big pin that is in the grooves of shift shaft the interlock mech. is run buy the shift cable top shaft is 1st 2nd bottom shaft is 3rd pull pin and  clean the dirt and chaff that is packed in the groove in 3rd shift shaft that wont let pin go all the way into shaft causing it to rub hard on top shaft when going into 3rd
