414/466 diesel injectors difference
Hi
While my engine project is underway, it's time to get the injector pump and injectors checked.
I have been given some good injectors for a 466, before I use them I am wondering if they are just the same as my existing ones out of my 414 or not.
Thanks, Brett
Out of a Truck, an Acco I think he said.
Brett
I have tested both tips on the dyno and the stock 414 burn cleaner and the 466 tips have a small amount of smoke out the exhaust , pump fuel not changed and it made 10 hp more . The opening psi was set at 3650 psi on both injectors .
Danny
Danny
Thank you Danny that helps me out. Interesting to know that
Brett
Danny
What are the differences in the nozzles?  Same hole #'s just bigger on the 466?
I would have to check for sure but I think the hole in the tip is alittle bigger , it’s been a few years since I did that test .
Danny
I am aware of at least 4 different size nozzles on 466 engines with out knowing which nozzle its pretty hard to take even an educated guess at what will happen.
