IH U-21
IH U-21 power unit
I have an International Harvester power unit.  what should the valve clearance set at.  Can't  find the information on it anywhere I've looked.
Might be able to buy a parts manual online for a U-21 but that wouldn't tell you. You know the cubic inches or if a tractor has the same engine?
U-21 is the power unit version of the W-40 / T-40 tractors. Built from 1935-1942. 3.75" bore x 4.5" stroke 6 cyl's. 298 cu.in.
the P40 power unit is the same engine as the w40 and t 40 tractractors. how did you come up with u21? post a picture of that unit. are you sure its not a U-12?? your talking about.
Model Fuel Cyl's B&S HP Range Years produced Where used
A-55(91cu in) G 4 2.875x3.5 49 1959-1960 Trucks
C-60 G 4 2.625x2.75 8~15 1947-1980 Cub. Cub Lo-boy, 154, 184, 185,
D-66 D 2 3.252x4 12~15 1953-1964 D-212,DLD-2, D-214, D-215,
D-74 D 2 3.437x4 15~19 1956-1966 D-217, D-19
D-99 D 3 3.252x4 20 1956-1966 D-320, D-322,
D-111 D 3 3.437x4 20~26 1956-1975 D-324, D-323, D-326
C-113 G 4 3x4 17~23 1939-1954 A, SA, C,
C-123 G 4 3.125x4 20~35 1951-1979 SC,100, 130, 140, 200, 230, 240
D-125 D 4 3.15x4 25 1951-1953 DF-25,
FC-132 G L4 3.25x4 33 1940 Trucks
D-132 D 4 3.252x4 30~40 1956-1965 D-430, D-432, D-440
C-133 G 4     1935-1938 Trucks, P-12 power unit
C-135 G 4 3.25x4.0625 30~46 1957- 330, 340,T-340
C5-140 G 4 3.3125x4.125   1935 Trucks
C-144 G 4 3.375x4 35~ 1971-1975 354,
D-144 D 4 3.375x4 30~40 1956-1971 B-250, B-275, 276, B-414,
C-146 G 4 3.375x4.0625 38 1964-1967 424,500
D-148 D 4 3.437x4 39 1962-1966 D-439,
C-149 G 4     1925-1927 Trucks
C-152 G 4 3.375x4.25 24 1939-1953 H,
C-152 G 4 3.875x3.21875 80~111 1967-1974 Trucks
C-153 G 4 3.375x4.25 47~53 1961-1971 504, 444, 2500, 3514, Scout
D-154 D 4 3.5x4 35~43 1976- 364, 434,
GermanD-155 D 3 3.874x4.373 34~45 1967-1989 353, 383, 423, 453, 533,
C-157 G 4 3.375x4.39 50 1970-1973 454,
C-162 G 4     1940 Trucks
C-164 G 4 3.5x4.25 31 1953-1954 SH
D-166 D 4 3.6875x3.875 40 1959-1965 TD-340,
C-169 G 4 3.5625x4.25 45 1954-1956 300
V-170 G 8     1953 Trucks
            Trucks
HD-174series G L6 3x4.125 46 1937-1940 Trucks
GD-175 G L6 3x4.125 64 1942-1946 Trucks
C-175 G 4 3.562x4.39 46 1973-1978 464, 350
GermanD-179 D 3 3.875x5.0625 50 1977-1984 484,
D-188 D 4 3.6875x4.39 46 1961-1968 504 2500 3514
C-192 G L4 3.5x5 20 1921-1927 Trucks
C-196 G 4 4.125x3.656 77~111 1967-1979 Trucks
C-200 G 4 3.813x4.39 55 1968-1978 544,574,674,2500A,B,2510B,3500
C-202 G L4 3.5x5.25   1915-1926 Trucks
GermanD-206 D 4 3.845x4.375 55 1971-1984 584
C-207 G 6   59 1933-1937 Trucks
HD-213series G L6 3.3125x4.125 78 1932-1940 Trucks
GD-214 G L6 3.3125x4.125 82 1941-1946 Trucks
BD-220 G 6 3.5625x3.6875 113 1957-1968 Trucks
SD-220 G 6 3.5625x3.6875 108 1948-1968 Trucks
C-221 G 4 3.75x5 25 1923-1939 Regular,F20,T20, Trucks
C-222 G 6 3.563x3.688   1940 Trucks
C-223 G 6   78 1933-1937 Trucks
            Trucks
HD-232series G L6 3.3125x4.5 81 1937-1940 Trucks
GD-233 G L6 3.3125x4.5 93 1941-1946 Trucks
D-236 D 6 3.6875x3.6875 75 1958-1967 460 606 3616, UD-236
GermanD-239 D 4 3.875x5.0625 65 1968-1984 544,574,664,674,2500A,B,2505B,2510B2514B,3500,3514,250A,260A,684,TD-7,TD-8C,TD-8E,125
BD-240 G 6 3.5625x4.018 141 1955-1960 Trucks
SD-240 G 6 3.5625x4.018 131 1948-1957 Trucks
FAC-241 G 6 3.375x4.5 84 1941-1946 Trucks
BLD-241 G 6 3.5625x4.018 141 1958-1968 Trucks
C-242 G 6     1941-1940 Trucks
C-243 G 6     1930-1936 Trucks
V-245 G       1957-1969 Trucks
GermanD-246 D   3.937x5.06 75~77 1978-1984 784,785,H84
C-248 G 4 3.875x5.25 38 1939-1952 M,W-6,T-6
D-248 D 4 3.875x5.25 37 1941-1952 MD,WD-6,TD-6
BLD-250 G 6 3.4375x4.5 100 1941-1953 Trucks
C-251 G 4 4x5 26 1917-1920 Trucks
FAC-259 G 6 3.5x4.5 89 1941-1947 Trucks
C-260 G 6   89 1941-1940 Trucks
BLD-260 G 6     1958 Trucks
BD-261 G 6     1953 Trucks
C-263 G 6 3.5625x4.39 51-85 1959-1971 560 656 706 403 T-62
C-264 G 4 4x5.25 50 1953-1960 SM,SWD-6,400,T-61
D-264 D 4 4x5.25 50 1953-1960 SMD,SWD-6,400,TD-61
BD-264 G 6 3.6875x4.018 154 1954-1960 Trucks
BD-265 G 6 3.6875x4.018 154 1966-1968 Trucks
V-266 G 8 3.625x4.21875 155 1959-1972 Trucks
GermanD-268 D 4 3.937x5.5 75 1979-1984 884,270A
BLD-269 G 6 3.5625x4.5 103 1941-1957 Trucks
RD-372 G 6 4.375x4.125 150   Trucks
BD-279 G 6     1929-1937 WA-40,Trucks
C-279 G 6 3.625x4.5 40~67 1930-1940 T-35,PA-40, Trucks
C-281 G 4 4.125x5.25 55 1956-1958 450,T-6
D-281 D 4 4.125x5.25 49 1956-1958 450D
C-282 G 6 3.6875x4.39 95   503
D-282series D 6 3.6875x4.39 55~80 1958-1969 560,660,706,TD-9B,H30,403
BD-282 G 6 3.8125x4.125 148 1953-1969 Trucks
C-283 G 4 4.25x5 30~40 1920-1939 10-20,F-30,W-30, Trucks, P-30,P-200
C-291 G 6 3.75x4.39 70 1963-1981 706,756,766,666,H70,686,H86
BD-298 G 6   94 1931-1940 WK-40,Trucks
C-298 G 6 3.75x4.5 40~67 1935-1942 T-40,W-40, PA-50/U-21 Power Units
FBB-298 G 6 3.75x4.5 94 1937-1940 Trucks
C-301 G 6 3.8125x4.39 105 1963-1971 806,856,826
D-301 D 6 3.8125x4.39 113 1960- 503,Trucks
V-304 G 8 3.875x4.21875 147~193 1962-1980 Trucks
BD-308 G 6 3.812x4.5 154 1952-1971 Trucks
GermanD-310 D 6 3.875x4.375     706,756,686,H86,3820,165Dozer, S7,B,
            Trucks
D-312 D 6 3.875x4.4 86 1971-1982 666,H70,686,H86
FBC-318 G 6 3.875x4.5 111 1941-1942 Trucks
C-335 G 4 4.406x5.5 45 1940-1956 W9,T9
D-335 D 4 4.406x5.5 40~60 1940-1956 WD9,TD9
V-345 G 8 3.875x3.65625 157~197 1962-1985 Trucks
C-350 D 4 4.5x5.5     600,650
D-350 D 4 4.5x5.5 55~65 1956-1959 SWD9,600,650,TD91
GermanD-358 D 6 3.875x5.06     826,786,886,3088,3288,280A,3964,3965,630
D-360  D 6 3.875x5.085 80-210 1994 766,886,S9B,Trucks
FBC-361 G 6 4.125x4.5 111 1937-1947 Trucks
D-361  D 6 4.125x4.5 95-115 1963-1967 806,1206,TD-15B
RD-361 G 6     1946-1950 Trucks
D-370 D 4 4.625x5.5
RD-372 G 6 4.375x4.125 165 1954-1969 Trucks
C-386 G 6     1925 Trucks
V-392 G 8 4.125x3.65625 187~236 1966-1985 Trucks
V-400 G 8 4.171875x3.6875 211 1973-1976 Trucks
FBC-401 G 6 4.125x5 114 1937-1942 Trucks
V-401 G 8 4.125x4.75 180~206 1955-1974 Trucks
GermanDT-402 D 6       650 Excavator
MV-404 G 8 4.125x3.75 188~219 1974- Trucks
RD-406 G 6 4.375x4.5 154~193 1950-1972 Trucks
D-407 D 6 4.321x4.625   1968-1971 1256,1026,1456,TD-15B,815,915,S9,
D-414 D 4 4.5x6.5 37 1936-1940 TD-35
D-414series D 6 4.3x4.75 1971-1985 1971-1985 966 1066 1086 915 530
420/6.9L D 8 4x4.125 170 1982-1987 Trucks
C-421 G 6     1925 Trucks
C-425 G 4 4.75x6 30-47 1929-1941 15-30, P-300
D-429 D 6 4.5x4.5 150 1961-1970 4100,4156,TD-20B,250, H-80
D-436series D 6 4.3x5   1971-1985 986,H186,H100,1466,1566,1486,1586,4166,4186,5088,6388,1460,1480
444/7.3L D 8   210 1993-2003 Trucks
MV-446 G 8 4.125x4.1875 235 1975- Trucks
FBC-450 G 6 4.375x5 120 1939-1942 Trucks
RD-450 G 6 4.375x5 160~202 1952-1972 Trucks
C-451 G 6   120 1937-1954 Trucks
C-461 G 4 4.75x6.5   1936-1940 T-14
D-461 D 4 4.75x6.5 43~76 1936-1940 TD-40,WD-40,TD-14,UD-14,PD-40
V-461 G 8 4.125x4.3125 226 1956-1965 Trucks
DV-462 D 8 4.5x3.625 185 1968-1972 Trucks
D-466series D 6 4.3x5.35 140-235 1971-1993 3488,TD12,175C,4366,4386,3588,3788,5288,6588,3788,6788,TD15C,E,5488.7288,7488,7388,1480,1680,540,433,412B,M10A, Trucks,ect.
V-478 G 8 4.5x3.75 209~234 1964-1977 Trucks
RD-501 G 6 4.5x4.25 181~215 1953-1974 Trucks
D-502 (UD-16) D 6 4.4x5.5 100 1948-1954 Power Units
FBD-525 G 6 4.5x5.5 107 1932-1940 Trucks
D-525 D 6 4.625x5.5 120 1954- Power Units
V-537 G 8 4.453125x4.3125 236 1976- Trucks
V-549 G 8 4.25x4.3125 227~290 1957-1977 Trucks, Power Units
DV-550/9.0L D 8 4.25x4.3125 150~210 1968-1985 1468,1586, Various trucks
D-554 D 6 4.625x5.5 85~ 1958~1962 TD15,150,151
DVT-573series D 8 4.5x4.5 180~260 1964-1984 TD-20C,250C, H90C,E. 270,E270, 65B,C. 1950Cargostar,4000COE
V-605 G/NG 8 4.625x4.5   1976- Trucks, Power units
FEB-648 G 6 5x5.5 100~140 1932-1942 Trucks,  Power units(PA-100)
D-691 D 6 4.75x6.5 75~140 1938-1962 TD-18,TD-20-201,Power Units(UD-18, PD-80)
PD-80(525) D 6 4.5x6.5 81 1936~1938 Power Units
DVT-800 D 8 5.3125x4.5 210~350 1975-1985 4568,4586,4786,7588,7788 TD-20E, 431, 433, 442, 444. 550. 4070,4370Transtar, 5070Paystar, 2524, 2624 2275 S-series
DT-817series D 6 5.375x6 235~420 1959-1983 TD-25,B,C,E. TD-30, PH-95,100,B,140,330,340.295,B. 4300, D-120C.H100C, H120C,560,Power units.
UT-817series NG 6 5.375x6 ? 1959-? Natural Gas Power Units
D-1091 D 6 5.75x7 190~235 1947-1959 TD-24, Power Units(UD-24)
U-1091 G 6 5.75x7   1954-1957 U-24 Power units
UDT-1091 D 6 5.75x7 300   Power Units
the valve clearance on the298 cid  FBB engine in the WK40 is .016 hot.  so pretty safe to say this on would be the same setting.
