Looking for some engine advice! DT 429, DT 436, TD20
I am looking for some wisdom about some International engines.
I have a International TD 20 with a DT 429 engine. This was given to my dad because the people that owned it didn't want to fix it. About a year ago the owners were building a roping arena in a remote part of Northern Nevada. They had some kid with "experience operating machinery" in the mines in Elko, Nevada operating it and leveling a semi flat part of property. He was probably working it hard and said it spit out a bunch of oil. It was running rough and he drove it a 100 feet and shut it down and it's been sitting there ever since. We don't know exactly where the oil came from, from the looks of it maybe around the oil cooler. At the time they drained the oil and did find some considerable pieces of metal. (I know that is pretty vague but it is what we were told)
I have pulled the valve cover off and rolled the motor over and it seems to roll over fine. Put batteries in, cleaned fuel system to make sure it was getting diesel it and turned it over. It just chugs and spits whiteish grey smoke and thinks about firing but won't start. I quit doing that in case there is internal damage to a cylinder or piston. I have pushed it onto a lowboy trailer with another machine and hauled it home for better inspection.
Here is the million dollar questions!
Rebuild the engine? It seems like this engine and parts are extremely hard to find
Is there another engine that would fit into it?  For example I have found several DT 436 engines in the 1460 combines that seem to be one every street corner here in Idaho.
Is a DT 436 engine similar (Inline 6 cylinder)? Would it fit?
Is it scrap? machine is in great condition, tracks are good, undercarriage is good, got a Caterpillar blade. We have a TD 18 that I am sure some of the parts would work for 886432081_20200506_104300(1).thumb.jpg.520200506_154740.jpg.52830493fee726f5e8b120200506_104329.thumb.jpg.6b79c62b3cffe3
Thinkin it's a 20B. As for fixing it would depend on what you want it for, if it has sentimental attachment or you want to restore it by all means go for it, if your looking for a worker, occasionally or day to day, scrap it. Parts are way to hard to come by, if not impossible and with this size of machine even when you could get parts they were expensive. You said the tracks are good but looks like the front idler is a long ways out and the pads are shot, that's about 15grand when you could get them.
Sorry can’t help you on your engine options but have seen a lot of different swaps MaGyvered in with some imagination, will and figuring, some better than others, bellhousing compatibly easier road, it looks to be a power shift and rather tidy
I don’t think much will cross over to your TD 18 except the tracks if they are standard duty, if they are severe or heavy duty they are a different pitch
Nice looking machine.
Believe I would pull into it and find out what happened.  Once that was determined , thin I would make a decision. Ether way , a machine in that condition I would get it going .
