5088 Puller project photos.
840919051_BUZA70451.thumb.JPG.6b7db63cf57edd654a0d832aa205e3f3.JPGSlowly making progress on the pull toy.  Steering rack is mounted, need to find some coilovers next    I cut down the knees of a stock wide front, cut the center tube out and made a 1/8" wall center tube.   I lathed new hubs out of billet for the 5X5 wheels.  Rack and pinion is a Mustang II style from Flaming river that is narrowed to fit.  I have a Prius 12v power steering unit that will be up at the platform.  MAYBE next year it will make a pass (not gonna hold my breath) or soon there after.
  • Like 19
Can’t imagine the amount of work that goes into one of those. Looks very nice Gonzo.
I stopped counting hours 2 years ago.   I have been working on some other projects too.  The 55 chevy project is a friends.   I put the engine together some time ago and is just now going into the car.
  • Like 7
Looking good Bob , are you planning on air bags too ? There really nice setup , the guy in Mondovi WI builds them along with the cages , frame connectors . When you finish up your drawbar build shims for under and over the drawbar , it’s way easier than the bolts /threaded rod . Let me know if you want pictures of how I did mine .
Danny
1 hour ago, acem said:
Nice looking puller and truck!
When building a 5x88 puller do you use the sentry or do something else?
Thx-Ace
The driveline is all 06 series tractor.   The sheet metal is from a 88 series. We (pullers) have learned what driveline 06-86 series is the toughest and easiest to modify for ratios.
Danny
I had settled on a coilover spring setup, But have not bought them yet.   I need to look at bags and cost.
Jackstands are ones I made to work on IH  differentials. The bases are brake discs from a JD 4430.
427? 454?  Beautiful engine.
454 Stock stroke forged crank  .030 overbore.  Good rods and blower lower compression pistons, Patriot oval port heads with some port work done O-ringed the block with Clark copper head gaskets..Comp blower cam with full roller assembly.    MSD ignition.   Dyer blower with dual 750 hollys .    The blower is about a 8% underdrive right now.   I suppose it would be in the 550-600 hp range.
  • Thanks 2
3 hours ago, twood1954 said:
Beautiful workmanship.  Can't wait to see it go down the track.
Thanks for the kind words.  I know that my fabrication skills are maybe average at best, I still enjoy building my vision.  Most of the engineering is done on cardboard with a sharpie and razor knife, and them LOTS of scrapped metal before I make an acceptable part.   One of my goals with the tractor is to haul it to the midwest sometime and get my butt kicked by the big boys.    Before that I have to figure out how to build fiberglass fenders and dash.    I still have to find a good intake water system, and learn how to snout drive the oil, fuel and water pumps.
Your more than welcome to stay at my place if you ever get to Minnesota with it!!👍🏻👍🏻👍🏻👍🏻👍🏻👍🏻👍🏻
That would be fantastic!!
Not to hijack your handiwork but in the vein of puller projects..... this is my new ride I’m building.
This is how I did my hitch on my cast tractor.  And the bolts make adjustments very easy    Really not sure about the “shims” he’s talking about make it easier.  This is cake. Make a quick adjustment at the scale and away ya go
I have a 1066 carcass that I would love to make a puller.   But sadly lack of time.    O yea and I spend all my money on the other tractors lol.
 Simpson makes the water system ................ makes it fool proof and completely simple   I've run his stuff on my diesels   Front drive stuff ....... again pretty simple
Did you move your lift pump to the injection pump drive? or are you switching it to a snout drive?   Who builds the log manifold for the fuel injection pump?    Threaded fuel injectors?   1 1/2" tubing on the new component tractor frame?
It's not the destination. It's the journey. I love seeing your fab skills. Thanks for sharing!
Yes and I have a stack of billet mounting plates that will put a tuthill pump driven of the front side of injection pump.  I love this setup over ANY version of an electric.  Number 1 reason ..... it matches fuel delivery with speed of engine.  Faster engine turns faster pump turns.  Electric...... you get what it has no mater what.  High volume and pressures can lead to idle issues and barrels n plungers stuck.  Yes new light super component is made of 1 1/2” tubing   I made that fuel log actually.   For some that are in familiar. This is one of the best ways to do this.  Put your 3 way shut off valve below the pump and you have one line up to dual feed the pump.  I put the pressure gauge on just so I can look at it when priming or cranking.  Yes this system primes with pulling the pump back (that’s part of why hoses make this handy) put a drill with a mating drive on it and spin it up.  It will completely fill the system quick
