farmall 300 hydro touch valves
hickory
My 300 leaks oil from the valve block. I want to try and find a gasket set before I tear it apart. The CaseIH web site is useless. Are there gaskets between the valve bodies or just orings sandwiched in there. Any help would be much appreicated.
Hickory
Just orings like shoe said.  I read on here about using bolts or threaded rod to make line up pins and disassembled the block on the tractor and changed the orings out on my 460, hardest part was getting there
