8950 dual pto sources
It has to be a later style wedge shaped( for lack of a better description) pto when one hits a salvage yard its scarffed up pretty fast. I have not seen any body with a kit to change those over.
I would like to have dual shaft units for ours IF they offered a big shaft 1000 and 540 in the same unit
7 hours ago, 756puller said:
Abiliene machine has a kit to convert large 1000 to small 1000 and 540. Did it to my 7130 years ago
Those conversions only fit the early PTO style.  The later ones ,89xx, you must find a dual unit.
We just did this using an old style big 1000 out of an early 7140. We used the kit from Abeliene machine. Get a gasket for an early style pto. You have to pull the plastic shield out and trim it to fit with the baffle on the back of the old style pto. Everybody said it couldn’t be done but we did it and the tractor has been doing pto work all summer with no problems. Forgot to add we put it in a 8940.
2 minutes ago, 706 German said:
Forgot to mention that it has to be the old style to convert it.
So you used an early 7140 style big 1000 and installed the kit to make it dual shaft both 1 3/8" or were you saying that you added 540 under the big 1000?
Yes, small 1000.
