IH 1066 injectors
We normally do a 13 mm head in the pump , .093 lines and a set of 5x.020 tips and set psi up to 4200 lbs opening . Make sure for 3000 rpm you don’t lock the advance in the pump or you will have no lug . If your going with the 13 mm pump you will need a double disk clutch/steel flywheel and Karl at Atlas Tractor up in the Twin Cities will set you up .  Timing needs to be set at 25 degrees with no water injection .
Do not go past 3000 rpms with the stock flywheel , don’t want you or anyone else getting hurt or killed .
Danny
Put the plate back in your pump or the advance won’t work in your pump . Make sure you measure your adjustment before moving them so you can put them back . Back the fuel screw out , tip the torque tab straight up  and back the droop bolt all the way out . If you do this stuff it will make in that 285 to 300 hp . I not sure if it will help you putting those tips in with out having the fuel to feed them .
Danny
