7 minutes ago, joefarmer said:
I'm looking for a grill  for the front of my International 656 diesel hydro. Anyone have one for sale?
they used two different grills what yr is your tractor?
19 minutes ago, joefarmer said:
sn# 12268..... 1969 model I believe
So it uses the bar style grille then?
Martin Salvage in PA?  They may have one.
If money is not a concern Wengers of Myerstown has at least one.  Here is a screenshot with the part number too.
Do you have a International or Farmall? They are different.
I have a 1969 656H myself. When I bought it the grill was gone as the bar grills fall out pretty easy. Although not correct, I put in the early 656/706 grill. They don't fall out.
Longer roll pins in the lower casting can keep the bottom of the grille from falling off.   Size them to just clear the mounting tubes during installation.  My 656 hydro has a rectangle plate that bolts to the upper cast housing to keep the grille from moving. Most of them are missing.   Nasty to install and remove, so most were discarded.
