AKwelder Posted August 31, 2020 Share Posted August 31, 2020 Getting ready to order the square head bolts to mount weights on the 460. Since we don’t have any dealers near I was going to order off McMaster, does anyone know how long they should be? i want to mount at least three sets on each side if it matters Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 31, 2020 Share Posted August 31, 2020 13 minutes ago, AKwelder said: Getting ready to order the square head bolts to mount weights on the 460. Since we don’t have any dealers near I was going to order off McMaster, does anyone know how long they should be? i want to mount at least three sets on each side if it matters Unless your wanting everything to appear original just use grade 5 hex 5/8 bolts not sure on the length but you can do some measuring Link to comment Share on other sites More sharing options...
WESnIL Posted August 31, 2020 Share Posted August 31, 2020 If your tractor is an International (utility) and if you can find out the length I have some extra square head in my inventory I could spare. They would be 5/8" diameter. Per the 460 parts book the bolt number for the first set is 365333R1 and 365332R2 for the second set. If a Farmall tractor the part numbers are 366110R1 for the first set of weights and 366111R1 for the second set. They would be 3/4" diameter. Link to comment Share on other sites More sharing options...
hobbyfarm Posted September 1, 2020 Share Posted September 1, 2020 I know not what you asked and not correct but I used threaded rod to hold 4 full weights on my 656. They have been on there like that for several years. I thought it was 3/4 but maybe it was 5/8? Link to comment Share on other sites More sharing options...
AKwelder Posted September 1, 2020 Author Share Posted September 1, 2020 Thank you gents 6 hours ago, WESnIL said: If your tractor is an International (utility) and if you can find out the length I have some extra square head in my inventory I could spare. They would be 5/8" diameter. Per the 460 parts book the bolt number for the first set is 365333R1 and 365332R2 for the second set. If a Farmall tractor the part numbers are 366110R1 for the first set of weights and 366111R1 for the second set. They would be 3/4" diameter. appreciate the offer, shipping might be a pain though Link to comment Share on other sites More sharing options...
Matt Kirsch Posted September 1, 2020 Share Posted September 1, 2020 Quick google search shows 366110R1 as a 3/4 x 4-3/4" or 5" long bolt. 366111R1 is a 3/4 x 3-1/4" bolt. McMaster only has full inch lengths. Link to comment Share on other sites More sharing options...
DT Fan Posted September 1, 2020 Share Posted September 1, 2020 17 hours ago, hobbyfarm said: I know not what you asked and not correct but I used threaded rod to hold 4 full weights on my 656. They have been on there like that for several years. I thought it was 3/4 but maybe it was 5/8? X-2 on the 3/4" all thread! Link to comment Share on other sites More sharing options...
801486 Posted September 2, 2020 Share Posted September 2, 2020 I just used threaded rods and square nuts and made whatever length I needed. Link to comment Share on other sites More sharing options...
