1256 3 pt arms
TeachersPet1066
you can slide the load and depth arm on the torsion shaft to get it to line up better with the upper link
1 hour ago, snoshoe said:
Just checking. They didn't come up untill you raised lever. Then won't go down until engine stops?
Correct.  They actually are still in raised position and not drifting down when lever is in up position with engine off.  With lever in lower position and engine off they will drift down.
