5488 clutch drag
Have my problem narrowed down to clutch drag is anyone able to send me update details on this going to take lubrication valve apart as it use to work fine
3 hours ago, Matt Kirsch said:
Also, what is "clutch drag?" Never heard of it.
When a clutch pack partially engages from a leak in a fluid circuit, like a stuck or damaged valve, blown o-ring or gasket.
But I have no idea where the OP is coming from or what his problem is either.
Edit: I'm going to add mechanical failure within the clutch pack to the above description.
When I try to shift low/med/high it's hard to get into gear the tractor creeps forward the gears do not bring. Pressure gauge shows zero with clutch depressed but still creeps forward like master us dragging
I am not familiar whatsoever with the 88 tractors....
Can you test pressure sent to a particular clutch to see if there is residual pressure being sent on that circuit?
Just taking a guess here, but maybe check out the cable from the clutch pedal to the valve linkage, possibly the cable is stretched, or some linkage to move the valve spool is worn, therefore not allowing full travel of the spool to disengage the master clutch
A fried clutch pack with warped plates can do that as SDman said. I had my MX150 start dragging the forward master clutch. Circuit pressure was zero when it was not engaged so it had to be a problem with the pack. Turned out not to be a roasted pack but rather I think a lost tooth of friction plate lodged in an oil hole of the clutch basket and kept the pack from fully releasing.
2 hours ago, 89vmax said:
There is only maybe 50hrs on new master clutch and 2 sp gone through.it was doing this previous to that work
Any more info you want to add so we know the whole story?
What I'm describing would not cause the tractor to creep, obviously. But; make sure the shift linkage is free and well lubricated, the Range lever can move both the M - H and the R - L linkage at the same time if it binds up.
Seems like we had one years ago that we capped the line that delivers lube oil to the master clutch/lube valve and tried it. It was noticeably different with the lube oil line capped off. Don’t remember exactly, but it seems like something was wrong in the MC/lube valve.
I would say that capping off the lube like SD man said would be a good test to see if lube was part or all of the problem.  Early 50 series were really tough to shift when cold and then the lube circuit was changed to reduce lube during total release of clutch.   I would think a sticking or  broken lube valve or spring could be your problem.
There was a change to the lube valve spool to help with this problem, especially in cold weather.  There was a service bulletin issued. Unfortunately I don’t have access to those any longer
i'd check the clutch cable before anything then go from there i had one do something similar and it was in the cable two years later it's still working great and be sure to follow the book on proper adjustment
