5088 Flow Divider Valve Spring
66 Series Farmer
Thanks to all the previous posts on here about this valve i'm sure that is whats wrong with my 5088. Sound/vibration was bad yesterday and again this evening when i first started it up. As soon as i put oil in the seat it stopped.
Still think i should probably replace the spring to avoid further damage. Can i remove the plunger without removing the whole valve assembly? Does anyone know the best place to actually get the right spring. I'm located in SE Iowa.
