Frost free extension...
So I installed a frost free hydrant this spring,
I thought it would have four feet of fill so I buryied it 2 feet.... Well it needed six feet if fill so the hydrant is at grade, any way to extend it so. I can backfill around it.
i buried a 6 ft frost free 5 ft. Froze and i had to run a hose every day till spring .i should dug it out that extra foot but i was tired. well i sure was tired digging it up and replacing it with a new one.. Lesson learned
Think you better get a new one while the weather is decent
And backfill with rock at least 2 ft for the water to seep out. I saw someone once who filled back with clay dirt and it packed the weep hole shut. He was not happy
You can extend the hydrant. As stated the outer is just pipe. The rod on the inside can be rod or pipe depending upon the brand. Getting everything the right length is the trick.
Buy the six foot rod. Then have a pipe cut and threaded to make up the length.
Not hard to get it right
Put a mark on the existing pipe and with the hydrant handle down measure to the center of the bolt in the handle that pulls the rod. Add the required length of pipe with the coupling and screw the hydrant handle back on measure again the difference between the two is the length the rod needs to be extended.
Cut the rod in the middle weld in the extension or thread and use coupling nuts.
Here a diagragm for a Woodford it has a pipe to operate the plunger
https://www.woodfordmfg.com/woodford/Yard_Hydrant_Pages/Model-y34.html
Mader:
Knowing your frustration with water supply issues from your previous posts on this forum, I would hire a professional plumber to perform the task.  Your mechanical skills may be up to the task but you seem to be snake bitten and have the worst type of luck, bad luck, when it comes to water issues.
1 hour ago, RichardDSalyer said:
Mader:
ID dig it up and replace cheaper than that...
Im trying for the no dig option, Creative option.
Or ill just dig it up next time I have a excavator up here...
I do hate plumbing i figure at 4 trips to the hardware store is average on any plumbing repair for me.
Return.  Get new one....they are generally 3' avove gound.  So a 6' sticks 3' down.....
This, it will never work right.
if your frost is at 3 foot go 4 foot and put 2 inches of foam on top.
If the line is critical lay 4 inches of foam under it, put heat trace on the line, and spray foam the line.
The point is, and what my Grandmother reminded me from time to time as a youth, "Son, if you do not have time to do it right the first time, how will you have time to do it over."
