Good morning all.  I am new to the forum.  I purchased a 1995 Dresser TD8G around the 4th of July.  The machine has been working great until yesterday.  I went out did all my checks and tuned on the master switch.  The voltage went up and then all of the sudden went to nothing.  I checked continuity on the master switch, nuetral switch, and checked the stop soleniod on the injector pump.  Going to go the starter system today, but was wondering if anyone had a wiring diagram for the machine?  I have the service manual, but niether book has a wiring diagram.  Any help would be appriciated.  Thank you.
I think the wiring diagram would be in the parts book, at least that's how the older dozers were. I can't help on this subject, but welcome to the forum.
DWF
Lammon, on the TD7, TD8, 100 and 125 C and E models there is an electrical system wiring diagram in the operators manual, parts manual and service manual, I am surprised it's not in your service manual.
Thanks for the info.  I am going to be getting the parts and operators manual soon.  I went old school and cut open the harness and started ringing out wires.  I found my problem and got it fixed.  It twas the power wire from the starter to the solenoid on the firewall in the engine compartment.  Did not even know that solenoid was there untill I removed the air filter housing.  On the bright side I learned alot about the wiring system of the machine.
Thanks again
