neukm 7 Posted August 13, 2020 Share Posted August 13, 2020 Came across this while browsing bigiron and thought I'd post it on the chance someone knows of a use for it rather than scrap. Not affiliated with the sale of it in any way. https://www.bigiron.com/Lots/CaseIH74884WDTractorFrontEnd Quote Link to post Share on other sites
Gearclash 845 Posted August 13, 2020 Share Posted August 13, 2020 Ahem @DirtBoyz07 !! Quote Link to post Share on other sites
J-Mech 1,176 Posted August 13, 2020 Share Posted August 13, 2020 If it only had the rear cast iron hinge/cover that bolted to the clutch housing....if only. 3 Quote Link to post Share on other sites
jass1660 1,968 Posted August 13, 2020 Share Posted August 13, 2020 2 hours ago, J-Mech said: If it only had the rear cast iron hinge/cover that bolted to the clutch housing....if only. Fabrication skills..... 2 Quote Link to post Share on other sites
bitty 5,328 Posted August 13, 2020 Share Posted August 13, 2020 4 hours ago, J-Mech said: If it only had the rear cast iron hinge/cover that bolted to the clutch housing....if only. 2 hours ago, jass1660 said: Fabrication skills..... It's a whole lot closer to something then nothing is ..... Quote Link to post Share on other sites
Reichow7120 1,750 Posted August 13, 2020 Share Posted August 13, 2020 6 minutes ago, bitty said: It's a whole lot closer to something then nothing is ..... Your not kidding really the hinging is the big sticking point. To be honest. If there's a way. It would be cool to put a Magnum back end on it. A Super 70 series powershift. That would be cool to see. 3 Quote Link to post Share on other sites
bitty 5,328 Posted August 13, 2020 Share Posted August 13, 2020 44 minutes ago, Reichow7120 said: Your not kidding really the hinging is the big sticking point. To be honest. If there's a way. It would be cool to put a Magnum back end on it. A Super 70 series powershift. That would be cool to see. X2 7150 rear end and engine 1 Quote Link to post Share on other sites
DirtBoyz07 1,269 Posted August 13, 2020 Share Posted August 13, 2020 If it only had that center section 😳 dang !! That thing would be in my shed bolted up to the IH powershift , Super 70 series powershift 👍😎 Danny 3 Quote Link to post Share on other sites
Gearclash 845 Posted August 13, 2020 Share Posted August 13, 2020 9 hours ago, J-Mech said: If it only had the rear cast iron hinge/cover that bolted to the clutch housing....if only. 51 minutes ago, DirtBoyz07 said: If it only had that center section 😳 dang !! That thing would be in my shed bolted up to the IH powershift , Super 70 series powershift 👍😎 Danny Hmmmmmmmm. There is a guy in Matlock IA that can make iron castings . . . 2 Quote Link to post Share on other sites
Farmall Doctor 483 Posted August 13, 2020 Share Posted August 13, 2020 1 hour ago, DirtBoyz07 said: If it only had that center section 😳 dang !! That thing would be in my shed bolted up to the IH powershift , Super 70 series powershift 👍😎 Danny Maybe the seller has it... and thought it was just some sort of casting.... you never know! Next question, where did the seller find that?? Quote Link to post Share on other sites
FarmerFixEmUp 1,000 Posted August 13, 2020 Share Posted August 13, 2020 1 hour ago, DirtBoyz07 said: If it only had that center section 😳 dang !! That thing would be in my shed bolted up to the IH powershift , Super 70 series powershift 👍😎 Danny Finney can build anything!! 2 Quote Link to post Share on other sites
Nebraska1206 153 Posted August 13, 2020 Share Posted August 13, 2020 Makes you wonder how many others like that are floating around........like down in Kansas, maybe???🤔 Quote Link to post Share on other sites
SDman 649 Posted August 13, 2020 Share Posted August 13, 2020 37 minutes ago, Nebraska1206 said: Makes you wonder how many others like that are floating around........like down in Kansas, maybe???🤔 Matt, you sure you don’t have something like that around there from the days of Hesse Inc? They had everything else down there when I was there 15 years ago or so. Still boggles my mind when I think about how much odd stuff they had around there at that time. Truly amazing. Quote Link to post Share on other sites
Gearclash 845 Posted August 13, 2020 Share Posted August 13, 2020 Is there some particular reason that the rear part of the hinge has to be cast? Anybody have a picture of that rear hinge? I got to thinking it may be possible to make it as a steel weldment, have the raw weldment normalized for better strength and to prevent residual stress cracks from the welding, then do whatever machining that would be required. Quote Link to post Share on other sites
bitty 5,328 Posted August 13, 2020 Share Posted August 13, 2020 28 minutes ago, Gearclash said: Is there some particular reason that the rear part of the hinge has to be cast? Anybody have a picture of that rear hinge? I got to thinking it may be possible to make it as a steel weldment, have the raw weldment normalized for better strength and to prevent residual stress cracks from the welding, then do whatever machining that would be required. It would most definitely be able to be made from plates welded together and machined to work. It would be time consuming to figure it out but then it would be fairly easy to make 1 Quote Link to post Share on other sites
Nebraska1206 153 Posted August 13, 2020 Share Posted August 13, 2020 1 hour ago, SDman said: Matt, you sure you don’t have something like that around there from the days of Hesse Inc? They had everything else down there when I was there 15 years ago or so. Still boggles my mind when I think about how much odd stuff they had around there at that time. Truly amazing. The vast majority of that stuff is long since gone. I never got to see any of this, and I have no idea where it went. I don't know if Bill & Mike retained any of that stuff, or have since sold it off? Granted, its been 14(?) years now. 1 Quote Link to post Share on other sites
DirtBoyz07 1,269 Posted August 13, 2020 Share Posted August 13, 2020 There would be a lot to building that hinge point , , gears , shafts , it would take someone with the equipment and a donor tractor for a pattern . Danny 3 Quote Link to post Share on other sites
5288IH 201 Posted August 14, 2020 Share Posted August 14, 2020 7 hours ago, DirtBoyz07 said: There would be a lot to building that hinge point , , gears , shafts , it would take someone with the equipment and a donor tractor for a pattern . Danny Just need a good 3d printer😀 2 Quote Link to post Share on other sites
dale560 2,036 Posted August 14, 2020 Share Posted August 14, 2020 2 hours ago, 5288IH said: Just need a good 3d printer😀 Exactly someone would print up a prototype easily. Quote Link to post Share on other sites
acem 1,439 Posted August 15, 2020 Share Posted August 15, 2020 Darn, I'm outbid. I'm short on funds, one of y'all will have to buy it. Thx-Ace Quote Link to post Share on other sites
J-Mech 1,176 Posted August 15, 2020 Share Posted August 15, 2020 As of right this moment, isn't the current bid $80?? Here are some pics of the hinge point that would be needed. If someone on here owns this tractor, I took these pics at a show last summer in Rantoul, Il. Quote Link to post Share on other sites
TractormanMike.mb 886 Posted August 15, 2020 Share Posted August 15, 2020 So by looking at the above pictures the hinge on the super 70s isn't a transfer case like on the 30 and 60 series? Does anybody know the story on this.front half? What happened to the rest of the tractor? Of the few super 70s built how many are accounted for today? Quote Link to post Share on other sites
mrfred54 199 Posted August 15, 2020 Share Posted August 15, 2020 The add is misleading.. It's not a case IH. It should be INTERNATIONAL 7488, correct?? I wonder the same thing, what happened to the rest of the tractor Quote Link to post Share on other sites
brahamfireman 302 Posted August 15, 2020 Share Posted August 15, 2020 2 hours ago, TractormanMike.mb said: So by looking at the above pictures the hinge on the super 70s isn't a transfer case like on the 30 and 60 series? Correct. The 5x88 series was a whole new transmission. If you got a FWA the front driveshaft came out the front of the transmission like normal. The super 70's ran the front axle from the same spot. 1 Quote Link to post Share on other sites
J-Mech 1,176 Posted August 15, 2020 Share Posted August 15, 2020 3 hours ago, TractormanMike.mb said: Does anybody know the story on this.front half? What happened to the rest of the tractor? More than likely this was salvaged by a test facility, or possibly a dealer or even a large farm. Remember that the Cade boys had all the Super 70's scrapped that were in the middle of production, along with finished undelivered ones. If someone found out what iron yard was dismantling them, I'm sure pieces could be bought. But my bet is this one is from a test tractor that was disassembled for inspection. The way that the Case boys had things cut up and destroyed is what really upset me, and a lot of other people. Such disdain and disrespect for the brand... but so happy to relable the engineering masterpiece tractor, the Magnum, as their own. 3 hours ago, TractormanMike.mb said: Of the few super 70s built how many are accounted for today? As far as I know, all of the ones sold are still accounted for. Going off memory, I believe it was 34 in all. 1 Quote Link to post Share on other sites
