The one inch tube that comes up from the oil pump and makes a 90 degree bend to the oil cooler is leaking around the fitting that goes into the oil cooler. I ordered the correct o ring from CNH and replaced it. The oil leak stopped so I cleaned it all up and let it run for about half an hour. No leaks then the next day it started leaking again . Is there another o ring I can try or do I need some kind of sealant. Thanks in advance.
APF
Than
1 hour ago, beekeep15 said:
read it on here before
Me too. Just could not find it. Thanks
APF
I just went through the same thing in my 806D.  There are actually 2 O-rings on each end of that fitting.. and the parts that I got from CIH didn't seem to be the correct rings even though they had the correct part number.  I ended up getting some out of an assortment set that worked.  Just make sure the elbow is clean when you reinstall it.
