robrj1951@aol.com 0 Posted August 10, 2020 Share Posted August 10, 2020 886 will not shift into reverse. Tractor is rarely used. Quote Link to post Share on other sites
560Dennis 1,396 Posted August 11, 2020 Share Posted August 11, 2020 Is the transmission differential locked up ? Does it shift into forward gears ? Quote Link to post Share on other sites
snoshoe 394 Posted August 11, 2020 Share Posted August 11, 2020 I think it might be safe to say. The problem is between the shift knob and the reverse idler. Quote Link to post Share on other sites
robrj1951@aol.com 0 Posted August 11, 2020 Author Share Posted August 11, 2020 On 8/10/2020 at 11:36 AM, robrj1951@aol.com said: 886 will not shift into reverse. Tractor is rarely used. It will shift into all other gears and into park , but not reverse. Quote Link to post Share on other sites
Farmall Doctor 483 Posted August 11, 2020 Share Posted August 11, 2020 Does the shift lever go into the reverse slot? Quote Link to post Share on other sites
robrj1951@aol.com 0 Posted August 11, 2020 Author Share Posted August 11, 2020 The shift lever will go from park to the mid position but no further. Quote Link to post Share on other sites
scraglycat 283 Posted August 12, 2020 Share Posted August 12, 2020 Simplest solution first would be dry or seized detent roller in the shift plate mechanism. Douse it down with lots of penetrating oil. I fought mine for a couple years, I'd pull the lever with one hand and hit it with the other to get it into reverse. At times when I would shift to park it would drag the high low linkage into high, so I'd be stuck in both park and high range at the same time. Started dismantling things expecting to have issues under the range cover, but after disconnecting the linkages it was obvious that all my problems were in the shifting plates. Got them lubed up good and it shifts like a dream. Quote Link to post Share on other sites
