t4mike
C 123 power unit engine, antifreeze in oil!
This  1960 engine has about 1500 hours and never taken apart.  It starts and runs perfect. I've had engine 25 years and always check/test fluids every fall.
Now i'm slowly getting trickle of antifreeze in the oil that builds up enough to notice a substantial over fill on the dip stick after sitting a month at a time.
Any ideas/help.
tia
This motor has wet sleeves sealed on the lower end by a single o ring. Drop the oil pan and check for leaks around the sleeves.
head gasket   wet sleeves
check as above... if you have an MTO near borrow pressure tester for rad  will show quick either in or outside of sleeve
