1256IHman
345 Timing?
I guess it varies. You time it off number eight cylinder. I started I think about five or six degrees BTDC and adjusted a little at a time till it was running smooth and pulling good. Don't remember where I ended up.
I usually set mine 10-15 degrees BTDC, running points ignition. I’ve found they seem to run the best in this range, but of course every motor is a bit different.
