Muddog
oil seal wear ring
I have a IH 574 pulled engine and have rebuild kit block cleaned crank polished and beginning to assemble having trouble with timing marks it seems the crank has a oil seal wear ring blocking the crank timing mark and I am having a problem trying to figure how to remove it or time the engine need help
Hi is this a German Diesel D-239 engine or a C-200 gas engine in your 574.
See Engine Service manual at this link below:
Does this provide you with what you are looking for?
believe he is saying the wear ring covers the crank mark...
replacement would be needed......surprised shop left it on there....?
ring should not be but .002 tight  with (correct tool)...bearing splitter in press behind gear and do both....carefully cut...dry ice...? heating...?  brass drift...    have a case of them setting here for cub,would need to be cut off,or pressed with gear,but they would not fully cover the marks.either...
photos/...
I used an old knife and drove it between the gear and the what ever you call it and it started moving and it finally came off.  I want to thank everybody for the help and info.  Now it is getting it back together and running
Thanks
if your talking about removing the speedy sleeve ,.. you just hit it with a cold chisel across the surface and they slide off. for next time.
