706 lift internal oil leak
While I have the PTO pulled, I have noticed that there is a noticeable oil leak when the tractor is running, coming up near the cylinder for the lift.  I think the leak is on the right side of the cylinder.  I know these valves are usually serviced by pulling the seat and top of the lift.  I just wondered if there was anything I could do or check, since I am in here anyway, before I put the pto back in.  Thanks!
Oil can be seen running down toward the right in this picture when the tractor is running, especially when you raise the hitch.  By the way, I noticed this after pulling the top link cover but before draining the rear end and pulling the PTO, in case you are wondering.
What you are seeing is normal. It is oil flow being dumped back to sump by the unloading valve. The gear pump has a constant volume of oil that has to be sent back to sump if no hydraulic function is on demand
As stated, the oil "leak" is normal, and it is working as it should.
