1256 hydraulic problems
Josh
Last fall while swathing with the 1256, the remote hydraulics all of the sudden started to get slow and in under an hour until it wouldnt even lift the table anymore. Where should I start? Is it likely the pump? Changing the filter did nothing.
if pressure is low, try swapping out relief valve with another. Easy to change, on the right side of seat casting. 1& 1/8 socket, just thread it out. 06,56,66, and early 86 series all the same except some have higher pressure settings. If you clean the paint off the valve, some had the pressure setting stamped on them
