JX100U shifting problems
8My son has a JX100U. It often times is a wonder tractor. You shift from forward to reverse and wonder if it is going to go. It seems much worse when it is in the high side on the 4 four speed. Sometimes it gets bad enough that we have to shut it off and start over.  The rabbit on the dash will flicker and nothing happens at all then. Any ideas?
Has the shuttle filter on right hand side of tractor been changed during regular service as well as the main hydraulic filter? I would also recommend an annual calibration of the transmission. On the JX100U you have to have a breakout box to calibrate, on JX1100U you can do it thru an on board diagnostic mode.
