Finney
Few small projects from the last couple of weeks.
First 2 is of a box scrapper on wheels that a company from Ala. is using to finish grade a new golf course. They had broke the the piece on the rear and put a new cutting edge on.
No. 3 is a new jack on a 24ft. shutz batwing. Jack is rated for 7,000lbs and is still hard to crank.
No 4 shows some of the modifications to pieces of ford truck frames.
I ended up just putting a 2nd jack on my 2620 bush hog, wind one a few turns then the other. took a little longer but much easier. 1 just would wear you out.
11 minutes ago, 1586 Jeff said:
Finney,
What size Ford truck are the frame plates for?
Jeff, they were not marked. The ones we are cutting now are 350/450. I was told they are changing the frames in August could be a part for the new ones.
Looks nice as always!
Todd
      He does as good a job at craftsmanship as you do!
Fred
Just now, GT&T said:
Todd
Fred
Thank you Fred. Finney is a pro. I’m just an at home welder scabbing things together.
