farmerole Posted June 6, 2020 Share Posted June 6, 2020 What'sthe proper way to adjust the high idle no load speed on the 8940? Link to comment Share on other sites More sharing options...
CIHTECH Posted June 6, 2020 Share Posted June 6, 2020 Disconnect your throttle cable from pump arm and work it by hand, then adjust the high idle stop screw until you get to 2500 no load. If you go much over this the rpm display will start flashing at 2650 IIRC indicating an overspeed. Now adjust throttle cable (s) to match arm on pump. Link to comment Share on other sites More sharing options...
farmerole Posted June 6, 2020 Author Share Posted June 6, 2020 56 minutes ago, CIHTECH said: Disconnect your throttle cable from pump arm and work it by hand, then adjust the high idle stop screw until you get to 2500 no load. If you go much over this the rpm display will start flashing at 2650 IIRC indicating an overspeed. Now adjust throttle cable (s) to match arm on pump. Will do...thanks. Link to comment Share on other sites More sharing options...
