Tunneldigger
5088 weight bracket
Will a 1486 bracket fit a 5088? I have mixed new and old weights and don't want to take a chance sliding off the end.
Yes, bolt spacing is the same. The 5088 has metric bolts though which may require a little honing in the bolt holes depending the base.
Gotta put spacers on it to push the weight bracket forward or the center weights will hit on the nose taking them on and off because it sits back to far
I don't know what front end your putting it on but the HD 2wd and the 4wd bolster uses larger bolts
