1967ihtruck 2 Posted May 21, 2020 Share Posted May 21, 2020 We have a 1086 with the digital tach. Just put a used sensor in and it is still showing erratic reading. For example when it is idling it shows 9xxx. What causes this? Quote Link to post Share on other sites
ky966boy 742 Posted May 21, 2020 Share Posted May 21, 2020 Mine was doing wild stuff and it was a ground problem. Quote Link to post Share on other sites
ksfarmdude 529 Posted May 21, 2020 Share Posted May 21, 2020 2 hours ago, 1967ihtruck said: We have a 1086 with the digital tach. Just put a used sensor in and it is still showing erratic reading. For example when it is idling it shows 9xxx. What causes this? You sure the used sensor unit is good ? and adjusted to the correct air gap? Quote Link to post Share on other sites
74A-472 18 Posted May 22, 2020 Share Posted May 22, 2020 i cured my digital tach problem after sending it off to be fixed and when it returned and still did not work .. i rented my farm ground out and sold my 1486 to my new renter. now he has a digital tact problem. i did not realize how great life could be with very few worries and wake up every day doing what ever you feel like doing. 1 1 Quote Link to post Share on other sites
Wi Ih 908 Posted May 22, 2020 Share Posted May 22, 2020 Mine was bad connection at back of display unit. Quote Link to post Share on other sites
Andejo 5 Posted May 22, 2020 Share Posted May 22, 2020 Mine was a ground problem. After tractor was split the ground was not reconnected. It would work like yours until it quit all together. I found the ground resting on the frame near the right battery. It now works like it should. Quote Link to post Share on other sites
88power 1,585 Posted May 22, 2020 Share Posted May 22, 2020 i have fixed more than one 5X88 that it was either a bad ground or a bad connection at the key switch or the key switch its self was bad. Quote Link to post Share on other sites
ksfarmdude 529 Posted May 22, 2020 Share Posted May 22, 2020 The old original tachs were more problems I updated mine to the later style and never had problems again Quote Link to post Share on other sites
nepoweshiekfarmalls 2,169 Posted May 22, 2020 Share Posted May 22, 2020 Low battery voltage can make them act goofy too. 1 Quote Link to post Share on other sites
IHC_1470 119 Posted May 23, 2020 Share Posted May 23, 2020 On the 2+2 it was a broken wire at the connector that goes to the RPM sender. Quote Link to post Share on other sites
Missouri Mule 1,693 Posted May 23, 2020 Share Posted May 23, 2020 On 5/21/2020 at 11:05 PM, 74A-472 said: i cured my digital tach problem after sending it off to be fixed and when it returned and still did not work .. i rented my farm ground out and sold my 1486 to my new renter. now he has a digital tact problem. i did not realize how great life could be with very few worries and wake up every day doing what ever you feel like doing. A little extreme over a bad tach dont you think😎 1 Quote Link to post Share on other sites
