The Goat Whisperer 0 Posted May 19, 2020 Share Posted May 19, 2020 hello, I have a problem with the 3 pt lift on the tractor. it will go up no problem and will hold an implement fine. When you move the lever to lower the implement the hitch is very slow to descend. Could anyone help with the problem ? the PTO works fine Also the steering is only under power when i have the auxiliary value in the up position to a dead end. Could this be linked ? i have a video just unsure how to unload Thank you for any help Quote Link to post Share on other sites
The Goat Whisperer 0 Posted May 19, 2020 Author Share Posted May 19, 2020 hello, video is as follows https;//youtu.be/fOZz1Z0rQfA Quote Link to post Share on other sites
jimb2 94 Posted May 19, 2020 Share Posted May 19, 2020 Probably dirt in the unloading valve under the seat. If you don't have a service manual they can be downloaded from the link below there is a whole section on trouble shooting and test the hydraulic system. Link: Quote Link to post Share on other sites
The Goat Whisperer 0 Posted May 20, 2020 Author Share Posted May 20, 2020 14 hours ago, jimb2 said: Probably dirt in the unloading valve under the seat. If you don't have a service manual they can be downloaded from the link below there is a whole section on trouble shooting and test the hydraulic system. Link: I’ve cleaned every valve as best as I can and it’s still no better ? there’s plenty of hydraulic oil as per the dipstick near the clutch. Unless it’s somewhere else ? Quote Link to post Share on other sites
jimb2 94 Posted May 21, 2020 Share Posted May 21, 2020 See below for a photo of the hydraulic flow of a 574, Quote Link to post Share on other sites
jimb2 94 Posted May 21, 2020 Share Posted May 21, 2020 Forgot to ask, if engine is OFF and you drop the 3pt does it still go down slowly? Quote Link to post Share on other sites
The Goat Whisperer 0 Posted May 21, 2020 Author Share Posted May 21, 2020 2 hours ago, jimb2 said: Forgot to ask, if engine is OFF and you drop the 3pt does it still go down slowly? yes if the engines off and you lower its still slow. they hold perfectly if you leave them up with engine off Quote Link to post Share on other sites
jimb2 94 Posted May 22, 2020 Share Posted May 22, 2020 See this post, same hydraulics as your 574. Quote Link to post Share on other sites
The Goat Whisperer 0 Posted May 22, 2020 Author Share Posted May 22, 2020 Hello, ive cleaned this valve and it’s fine it moves as well Quote Link to post Share on other sites
