Wes806
1999 Ford f350
Bought a 99 f350 with the 7.3 it has been sitting about 2 1/2 years. Everything worked on this truck before it stopped running on him . (Fuel relay went bad ) got it to running good but I have no dash gauges or speedometer  and the heater motor fan doesn't work. Fuses and relays look to be good and fuses check out. Any ideas on this. As said they all worked good when he parked it. Thanks
Here's a pic of the truck
First thought MICE have helped out with the wiring some where.
So far I haven't seen any signs of that
Maybe a master fuse under the hood in the box blown. Neighbor had an 07 that did that.
In-laws had an explorer that the gauges and some other crap was tied in with the ABS fuse, I pulled it one night in a snow storm and lost a lot of stuff, had to put it back in.
Off the top, I think power comes in to the key switch then goes to the fuse box under the dash. Check for power at the appropriate fuse. This allows the engine to start but no gauges etc. Same for the blower, check for power at the motor, the speeds are controlled by a resistor, check for voltage with switch set to high.
Did that year have the GEM in them or did that come later?
If you get discouraged , working on it , I will be a member of your support group. Just saying I’m here for you Wes!
check the air filter box ,it might be full of acorns like my 89 F350
Wes
     These trucks have what Rawleigh99 has asked, above.    They have a (GEM)  Generic Electronic Module, mounted behind the fuse panel that is just ahead of your left knee.   This GEM is a bugger to get out.  You will need to remove the fuse box and the parking brake release lever.    Then with a 1/4"  10mm deep socket remove 2 hex bolts that are in the center of each of the wiring harness connection blocks.    There is "almost" enough room to work on these.
     The GEM has control of these functions, and maybe a lot more:  electric windows, radio, heater, A/C, cruise control, speedometer, interior lights.
     There is a You Tube video that shows what is required to remove the GEM.   I will try to link it here:
     I hope this helps you.
GT&T
Has a K&N air filter system on it.  Having a hard time with this one. All fuses have power to both sides which tell me I should power. Up on checking more in to it . The low beam lights don't work , no 4 way flashers. and had a sanner put on comes up link error. If the GEM was bad Would I still haver power on both sides of fuses?
DITCH THE K&N!!!!!! lots of diesels have been ruined by them. The high air volume of a boosted diesel literally sucks the oil out of the filter media, leaving you with a crap filter.
Look into the napa 6637 air filter.
I like the looks of your truck. Hopefully things get straightened out.
I will second the K&N removal. More air in also means more dirt in.
enjoy the old girl............i dont have a k&n but i have aftermarket, got 315K on  mine and it doesnt burn any oil yet knock on wood ..........6.0 though
I was starring at electrical schematics till late at night trying For 4 days to figure why the lights  , ugh I will stop there but mice chewed the wiring harness ,also replaced  hazard and directional, switch, ugh 😩
good luck  but a truck or car that sits is a nightmare ,
A colleague of mine put everything on his truck that promised some percentage of more power. If he added it all up it would have been making at least 100% more😁. I'm pretty happy leaving everything stock myself unless it's to fix an actual flaw. Stock air filters generally do a good job and lots of new vehicles have a clog indicator.
I like how the young crowd brag about what they have under the hood. Start out with stock 215 hp, add 100 hp injectors, now 315, cold air intake add 25, now 340 an on & on. Local diesel shop had a "dyno day" more left with their tail between legs than not. Probably still can't figure out why their numbers don't add up.
Me, I will just leave it stock, an oh......... I have a strong dislike for K&N intake filters.
The K&N filter will be gone and back to factory. Just want to get everything else working first.
I had an ignition switch go bad years ago and it did something similar. I think. Oldtimers is catching up.
I agree. Mine is stock. It has plenty of power the way it is but reliability is my biggest concern. Normally power aids seems to come with more wrench time fixing things from what I have seen.
Lol.  It’s been the same way since the first model T got an after market product.  Back when I was in high school it was intake manifolds, headers, and even magnets on the fuel line.  They do try
Last one I had like that I just swapped the entire fuse box not hard to do if you have a spare or can borrow one they have issues with the fuse box going bad
I going to try and find one and replace it.
I love dyno days, everyone's 800hp trucks leave making 400hp.
My 580hp truck puts 422hp to the wheels, nothing impressive these days.
