Need a Lh. Head light shroud 5x88
iam in need of the lh front head light shroud  hate to by a set. My rh is fine. Just a working tractor.     This is the first spring and birds are building nest behind fan. Just need to stop them.     There's not any in salvage around me.
Damm, I just threw a set away a month ago from an LED upgrade I did....
      someone on here is parting out a 5288 I think.
  • Sad 1
there is a guy in pattonsburg mo that has a 5088 he is parting out - red is his name 660/605-2007 ive tried to buy a couple things from him but 1) he wasnt reasonable on the first item and 2) he didnt ever call me back with a price on the second one so good luck
Are you looking for #3?Screenshot_20200516-153615.thumb.png.96cb71bc3fd9ab8c3310eb462dd27145.png
Also. What holds the grill in?   Mine seems to be just stuck in.   I thought the light collar held it but it doesn’t
Mike links has them and we used apoxy to glue the grills in.
If you glue the grill in. How do you clean it. If it needs it ?   Or to spray radiator out.
Take the nose off you gotta pull the side panels the one on the driver side anyway to get to the plate that you remove to service the condenser and hydraulic oil cooler to properly wash it out you go in that way to get to the bottom of the radiator we wash the alternator but it's just six more bolts on the nose with an electric rachet
I bought one from "cuss" IH a few years ago and it was made out of probably 18 gauge steel. Didn't like it at all, was too heavy, so ended up getting a NOS plastic one from Anderson Tractor Supply in Bluffton OH, but pretty sure he said it was their last one. Might try them anyhow? 855-333-5755. As mentioned above, Mike Links used to have them, dunno' about now? He's a real straight shooter!
The grill screen from the factory was stapled to the nose piece.  The nose is made out of some type of rubber material.  I used stainless steel panhead crews when I put mine back together.
I have one in my stash of 88 parts.
IMG_20200516_193654037.thumb.jpg.cb262763f3407c8762f6de710017523e.jpgIMG_20200516_193701372.thumb.jpg.3a2b06b3703dedf1108a1c4248dd8fe4.jpg
Ihc 5488.   Would you consider letting it go?
