5088 3 pt claws
The 5088 I bought has the claw quick hitch 3 pt arms. Not a huge fan of them. Assume you have to have the ball inserts for them like the old John Deere’s. Where could a guy even begin to find these ? Really just thinking about going to salvage yard and replacing the whole lower arms.
any thoughts or experiences with them?
they are cat 3 balls on mine presuming factory size, you could put 2 on it if you wanted and dont think u need the 3 i suppose
I dont like the claws either but thats just me, some folks like them i have heard
Haven’t tried mine Yet obviously But just not a fan of the look, which I know is silly. I do know I fell in love with the quick hitch on my 1466. I hook and unhook from the brush mower and my heavy blade a lot by myself
I haven't gotten to try mine either, they make guide plates to help aline them.      I have thought about measuring and see if the arms from a 66 would fit
If I remember correctly bitty cut the hooks off and welded ball on a while back
try searching it
The standard ball lower links that fit 5X88 series tractors are the same as used on 86 series, 2+2s . Should be easy enough to find.
57 minutes ago, Matt Kirsch said:
Euro spec tractors? Seems like all the ones imported from overseas have claw hitches.
The claw hitch was an option available here.
Don't like the look, that is not silly, it's your tractor. Put it the way you like it. I agree don't like the claw hitch at all.
Rusty Shakelford put arms off a Magnum on his 1456, so I think 66 series would work on an 88 series.
13 hours ago, IHC5488 said:
I like the claw style, back up, get them close and raise.  Makes it convenient when no one is around to help.
Matt
Would you say they are better than a quick hitch?
I would say yes coming from a quick hitch:
1. Quick hitch always seems to be in the way when not using it, so you have to take it off.
2. You inevitably hit your head on the quick hitch if you don't take it off.
3. Looks like more flexibility in what you can hitch to it. Quick hitch is limited to quick hitch compatible implements.
A set of those would be really nice for hooking up the discbine and the bale wrapper. Neither one is quick hitch compatible and both are a pain to hitch up to the point where you just want to hook them up once and leave them on the tractor, but we don't have enough tractors to do that.
I have never had a quick hitch. So I can't answer.
But with the claws, you can back under the implement and raise the arms only.  With the standard style you have to hold them out, raise and or lower and it usually takes 2 people to do so.
JMO,  but that is why I like them better.
Matt
Matt
We have had quick hitches for years mainly for two point drills and then they had someone talk them in to buying a set of claws but when they sold them to them they never gave them the balls or the lower link adjustable spacer (without the spacer even with a rubber strap it wouldnt be as rigid as a quick hitch like we would like) so now we are in the same shape as the op on that one tractor i asked because i didnt know if it be worth fooling with or not
