dannyredfan 467 Posted May 10, 2020 Share Posted May 10, 2020 I have a 2656. Hydro seems ok uses the foot pedals. The loader is ok but not great a little slow not super powerful. But the 3point hitch is about useless. If you're above 1/2 throttle the loader is faster but still not real strong. The lift arms will barely lift a grader box. It does not settle after it has lifted it will stay up for days. Changed filter ,changed releaf valve, Assuming the pump is bad? What's your all thoughts? Quote Link to post Share on other sites
J-Mech 1,156 Posted May 10, 2020 Share Posted May 10, 2020 Two pumps on that tractors hitch hydraulics. Big one is for the remote valves, second "piggyback" pump is for the 3pt, but when the 3pt is not in use it supplies oil to the remote valves. Sounds like a weak piggyback pump to me, but you should test it to be sure. Quote Link to post Share on other sites
dannyredfan 467 Posted May 10, 2020 Author Share Posted May 10, 2020 Just tested the loader it has 1900 psi not sure where to test 3pt but I think your right Quote Link to post Share on other sites
R190 168 Posted May 11, 2020 Share Posted May 11, 2020 your just testing pressure volume moves things you could also have a leak where the piggy back pump mounts (O-rings 2 places) but I would guess the hitch pump went south Quote Link to post Share on other sites
