Mtb
Lost serial number
First off a big hello to all, new to owning a red machine just could not resist a petrol / tvo T6 crawler but I cannot find a serial number tag on the machine I have taken a photo of the engine number does that help with identifying?
hopefully your expertise can point me in the right direction
mike
mike
TBKM 5701 T3   T= TracTractor  BK= Series 6  M= (motor /engine)  First production unit was #501 in 1940, so yours appears to be the 5200th engine built.  T-3 is a "track option"
I assume you are located in Britain as you say "petrol / TVO"  rather than the American "gasoline/distillate" or the Australian "power kerosene"
regards from Michael H.
Thank's for the reply's
yes from uk Scottish Borders
Is the engine number the same as the serial number or am I barking up the wrong tree ?
mike
mike
Unfortunately they're not   . BUT I have found some information for you. The T3 suffix means "kerosene option" when its used on a engine  and "T1" means "gasoline engine". I have found a production list of engines built for the T-6 crawler and that engine serial number was from early 1948. I assume this is the original engine fitted to the crawler. I assume this tractor was used for farm work as it has no dozer blade and the TVO fuel option was mainly used on farm tractors. There was a British built equivalent model called the BT-6 which was, to the best of my knowledge, only built in the TVO style. The engine in used in the T-6, from that era, is largely the same as used in the W-6 & Farmall M tractors which is handy when sourcing engine parts.👆
Regards from Michael H. in Australia.
Thank you for a very informative insight as to when the crawler was produced I am looking forward to bringing it back to life and using it for the odd job around the property, Ransomes wheeled mole plough springs to mind.
Small technicality--that is the 5201th built.
Look at it this way, if the serial were 502 and you subtracted 501, you'd say it was #1, not #2.  You have to subtract 500.  Common mistake.
