MCV valve question
Looks like somebody tried the aftermarket “tender foot shifting” kit on it.
thinking about it that may have been for shifting the sprag less ta’s
Doesn't look like the original MCV looks like its been replaced
Could have just been cleaned.  I have a jet tank that is heated.  I've washed IH parts in it thoroughly and sometimes they come out and are faded like that.  It will pull most all the paint off if you leave it in long enough.  I do not use a caustic solution.  Just a powdered soap that can be dumped down a drain during clean-out.
12 hours ago, beekeep15 said:
whats
that line coming out the bottom for
Supercharge line from the hitch pump.
I never tank those I only power wash the outside and use solvent cleaner or brakleen on passages and its good to go
I used to tank all parts except small ones.  It did the cleaning while I did other things.  Saved hours and hours of time cleaning parts.
2 hours ago, mrfred54 said:
Got to be 86series with the supercharge line
And the fuel tank, and battery cables, and clutch linkage.......
  • 3 weeks later...
