460 Hydraulic Capacity?
Super C Fan
My Farmall 460 blew a hydraulic line so I got that brazed, and also drained the hydraulic fluid and changed the filter.  My book says that the tractor takes 10 gallons of hydraulic fluid, but only five came out after draining two drain plugs and opening the filter compartment.  Also only took five gallons until the check hole began to dribble.  What am I missing here?
There are three drain plugs.  one at rear of transmission, one at front of transmission facing forward and the one under the TA housing.
