1965 TD9 B series IHC injector pump Help
I have a 1965 TD9 B series IHC 6c4088 injection pump that leaks around the throttle shaft.  I can find no rebuild kits, or even a shop that will work on it. Is there someone here that rebuilds these pumps or has a suggestion?
Thank you!
https://www.redpowermagazine.com/forums/topic/112850-806-rd-pump-throttle-shaft-seal/?tab=comments#comment-1175013
Try this IHRD had a wealth of knowledge on these haven't seen him around for awhile...this thread references IHBRAD not familiar but might also help?
Put this on the General IH side too. Dirtboyz07 is knowledgeable on pumps along with a few others that will probably see your thread. I had a TD9B and for the life of me can't remember that pump, must have never had trouble with it. I had a TD9-92 series with the DT282 engine and it had a Roosa Master pump. I remember that because I had it off for repair.
DWF
