IH 666 auxiliary valve won’t go back
I have an IH 666 that had an auxiliary valve leaking pretty bad. I replaced all the o-rings inside and the piston with the tiny o-ring. When I put it back together and put it in the tractor I can get it to go forward and backwards but once I screw on the cap the lever will not go into the back position, only forward. What am I doing wrong??? When you put the actuator and the sleeve together what position should the sleeve be on the actuator? Thinking maybe I m having an issue with that as when I take it back apart the sleeve is no longer in position. Thanks.
