Driveline651 1 Posted April 8, 2020 Share Posted April 8, 2020 I wanted to post the factory wiring diagram for the 88 series sentry system . I am pinpoint testing my system to ensure I don't have an issue that isn't the actual module (my sentry light is coming on for the low /odd side gears) I was unable to find a factory schematic online , so I was able to take a picture of the schematic from my local dealer . Just wanted to get this resource up for anyone else looking to check things . this picture is of the early system AFTER dealer updates . The newer system is the same as the one pictured , the early system has a different clutch switch , and I was told they have all been updated to this . the solenoids ohm out around 2.5 ohms . The pressure switches are normally closed . The system operation seems pretty basic , the hi/low switch located on the lever , tells the module which mode has been selected , the module then applies power to the solenoid for the range selected , and removes power from the other . It then looks for the pressure switch signal , the one coming on must open , while the one coming off must close . If your system has failed in a way where the tractor won't move , or bound up in both ranges at once , I think you could simply apply power to the solenoid , hi or low not both to get it to move enough to get it home or in the shop . (This advice is not professional , try at your own risk) but if you're able to read the schematic and follow along , you should be able to form your own opinions . I think building building your own with time delay relays or a programmable Plc board would be pretty straight forward . I have read the threads on the ideas and build on this forum . However , I have not seen anyone say what the actual time delays are . I:E what is the delay for the off going solenoid so as to not shock load the system? Is it .5 , 1, 1.5 seconds ? if anyone has this info , or is able to test their working system and report back , I think that would be very helpful . 1 Quote Link to post Share on other sites
superih 274 Posted April 9, 2020 Share Posted April 9, 2020 Nice work Quote Link to post Share on other sites
5288IH 197 Posted April 9, 2020 Share Posted April 9, 2020 16 hours ago, Driveline651 said: I wanted to post the factory wiring diagram for the 88 series sentry system . I am pinpoint testing my system to ensure I don't have an issue that isn't the actual module (my sentry light is coming on for the low /odd side gears) I was unable to find a factory schematic online , so I was able to take a picture of the schematic from my local dealer . Just wanted to get this resource up for anyone else looking to check things . this picture is of the early system AFTER dealer updates . The newer system is the same as the one pictured , the early system has a different clutch switch , and I was told they have all been updated to this . the solenoids ohm out around 2.5 ohms . The pressure switches are normally closed . The system operation seems pretty basic , the hi/low switch located on the lever , tells the module which mode has been selected , the module then applies power to the solenoid for the range selected , and removes power from the other . It then looks for the pressure switch signal , the one coming on must open , while the one coming off must close . If your system has failed in a way where the tractor won't move , or bound up in both ranges at once , I think you could simply apply power to the solenoid , hi or low not both to get it to move enough to get it home or in the shop . (This advice is not professional , try at your own risk) but if you're able to read the schematic and follow along , you should be able to form your own opinions . I think building building your own with time delay relays or a programmable Plc board would be pretty straight forward . I have read the threads on the ideas and build on this forum . However , I have not seen anyone say what the actual time delays are . I:E what is the delay for the off going solenoid so as to not shock load the system? Is it .5 , 1, 1.5 seconds ? if anyone has this info , or is able to test their working system and report back , I think that would be very helpful . I would also stick a pressure gauge on it so not to damage transmission if pressure gets low, that is why the sentry was designed for 1 Quote Link to post Share on other sites
Driveline651 1 Posted April 30, 2020 Author Share Posted April 30, 2020 Update : I wanted to confirm that the side not working (low side)on my tractor was capable of working , and that the sentry was not adding power to the solenoid , and was properly removing power from the side that was working (high side) when I selected the other . I clamped on a power probe to the blue wire going to the high solenoid , and as expected the sentry added 12v when the high side was selected and removed 12v when the low side was selected . moved power probe tester to the other blue wire that goes to the low side solenoid , showed no power no matter what I did with the lever or clutch , meaning the sentry was not adding power to the low side , but it was removing power from the high side . Having manually actuated both high and low solenoids previously and watched the new pressure switches operate properly I was fairly confident that the wiring, solenoids,pressure switches were all functioning properly . So I added 12v to the wire going to the low side solenoid with the power probe and the tractor moved in the low side confirming that it was a bad sentry . (I was sure not to wiggle wires or tug on things during this process) But , here is the weird part , the sentry kept power to the solenoid after I stopped applying power with the probe ! Ithen moved the lever to the high side and it went to High , no volts showed on wire to low solenoid as it should , selected the Low side and IT SHIFTED to the low side , showing 12v on the wire again ! I disconnected the power probe and ran the tractor up and Down the road for about 30 minutes , shifting it through all the gears , and HIGH /LOW at least fifty times it stayed working ... I'm not sure what adding power to that wire did to the module to make it start working , but I hope it stays working ! Quote Link to post Share on other sites
searcyfarms 2,472 Posted April 30, 2020 Share Posted April 30, 2020 46 minutes ago, Driveline651 said: Update : I wanted to confirm that the side not working (low side)on my tractor was capable of working , and that the sentry was not adding power to the solenoid , and was properly removing power from the side that was working (high side) when I selected the other . I clamped on a power probe to the blue wire going to the high solenoid , and as expected the sentry added 12v when the high side was selected and removed 12v when the low side was selected . moved power probe tester to the other blue wire that goes to the low side solenoid , showed no power no matter what I did with the lever or clutch , meaning the sentry was not adding power to the low side , but it was removing power from the high side . Having manually actuated both high and low solenoids previously and watched the new pressure switches operate properly I was fairly confident that the wiring, solenoids,pressure switches were all functioning properly . So I added 12v to the wire going to the low side solenoid with the power probe and the tractor moved in the low side confirming that it was a bad sentry . (I was sure not to wiggle wires or tug on things during this process) But , here is the weird part , the sentry kept power to the solenoid after I stopped applying power with the probe ! Ithen moved the lever to the high side and it went to High , no volts showed on wire to low solenoid as it should , selected the Low side and IT SHIFTED to the low side , showing 12v on the wire again ! I disconnected the power probe and ran the tractor up and Down the road for about 30 minutes , shifting it through all the gears , and HIGH /LOW at least fifty times it stayed working ... I'm not sure what adding power to that wire did to the module to make it start working , but I hope it stays working ! im not sure how intelligent these sentry's are but it reminds me of removing power from ANY electronic device and resetting it - maybe that is what happened ? removing the battery power to the tractor overnight might have done the same thing ? Quote Link to post Share on other sites
Driveline651 1 Posted April 30, 2020 Author Share Posted April 30, 2020 1 hour ago, searcyfarms said: im not sure how intelligent these sentry's are but it reminds me of removing power from ANY electronic device and resetting it - maybe that is what happened ? removing the battery power to the tractor overnight might have done the same thing ? I added power to the wire the module should output power to the solenoid . I wasn't on the power or ground input side to the module . I also believe that depressing the clutch resets the sentry , and I have had this module out overnight in order to perform all of the other testing . I wish it would have fixed it just by removing power ....... Quote Link to post Share on other sites
Delta88 28 Posted April 30, 2020 Share Posted April 30, 2020 So are you bypassing the sentry power harness and going directly to the solenoids with a jumper wire? Quote Link to post Share on other sites
Driveline651 1 Posted April 30, 2020 Author Share Posted April 30, 2020 31 minutes ago, Delta88 said: So are you bypassing the sentry power harness and going directly to the solenoids with a jumper wire? I did that previously while watching the pressure switches with a volt meter . This was with the sentry hooked up and used a power probe tapped into the wires going from sentry to solenoids , bl/wt and bl/Blk Quote Link to post Share on other sites
Delta88 28 Posted May 1, 2020 Share Posted May 1, 2020 Sounds like I am having a similar problems. Mine is stuck in the high side; with no power going to the low solenoid. Going to try a new pressure switch but the sentry seems to be working. Quote Link to post Share on other sites
Driveline651 1 Posted May 1, 2020 Author Share Posted May 1, 2020 16 hours ago, Delta88 said: Sounds like I am having a similar problems. Mine is stuck in the high side; with no power going to the low solenoid. Going to try a new pressure switch but the sentry seems to be working. Yes mine only worked on the high side , and if I selected the low side the sentry light would immediately come on . I checked all powers and grounds , added a ground as per the update , verified cab to chassis ground good ( cab is isolated) checked micro switch and wires for proper operation . I had replaced the pressure switches with updated style (no help) I then disconnected the sentry , ohmed out solenoids , and then installed an ohm meter on the switch and while monitoring the switch added 12v to the corresponding solenoid with tractor running in neutral . Confirmed the solenoid allowed enough pressure to open the switch , then did that on the other side . (Only one side at a time so you don't engage high and low at the same time) I then ohmed any other wires in the system to confirm no shorts or opens. i was then confident that the sentry was bad . I reassembled the tractor and reinstalled the sentry and tested it with no change ( a guy can hope) A week or two later I hooked up the power probe and added power to the low side solenoid with everything hooked up , and it somehow woke up the module . if you conclude that your sentry is bad , I would suggest you try adding power like I did ( confirm low side selected an no power going to high side solenoid prior) and add 12 v to the wire going from sentry to low solenoid while everything is hooked up . Mine might have been a fluke , but it worked for me ... Might work for you , who knows.. If you try it , please report back with your results either way please . Quote Link to post Share on other sites
Delta88 28 Posted May 2, 2020 Share Posted May 2, 2020 When you added power to the low side solenoid ( causing the sentry to come alive) did you have it unplugged and were using a jumper wire off a battery? With a jumper also to a good ground location? My sentry is getting power from both sides of the harness; Plug A on the male side with power going to the sentry light via plug C; and plug E has power going to the switch. The female side of the harness has power on the A plug. So power going into the sentry isn't the problem. Quote Link to post Share on other sites
