FARMALL 1206: SN 14917
Long Farms
  • Replies 61
  • Created
  • Last Reply
12 minutes ago, Long Farms said:
Traded for this 1206 few months ago. Weather and time has permitted to start cleaning and fixing it up.
I have to say love watching the pictures of you cleaning them up. It is a tutorial on how to properly fix and repaint one of these old girls.keep the pictures coming.
Looks like a real clean nice original, is there other ends for the 3rd arms to screw on that matches the 1206 hook that wasnt 1206? Also I never seen the pto under the levers like that
5 minutes ago, Qc.Can.IH man said:
What is that lever under the 3 point hitch controls for?
Got to be PTO
Not all 1206's got the claw end.  There was a serial number break where the claw went away and the ball end was used.
9 hours ago, nepoweshiekfarmalls said:
I have never seen a PTO lever distorted to operate in that position before!  Did this 1206 have the factory bracket for the flashing light?  Looks like a real clean 1206.
From what i was told when i got it it came from South West KS. Friends 1206 SN 14869 came from North West OK so they are close in SN and options. Mine was factory fender delete  but had an aftermarket cab on it. It still had the factory fender delete fasher bar which i put on my 856 since its fenders are removed for dozer work. This 1206 is cleaning up real well.
1 hour ago, Long Farms said:
No, i dont paint them. Under my ownership they wont get that filthy again but if i was to paint a tractor i would pull them back off and paint back side.
My truck sales buddy up here is as intense about dirt and grease as you are. You can crawl under a truck he has cleaned and look for dirt and oil but you won’t find any.
Spent half the day running errands. Picked up fresh oil, antifreeze, oil pump Tube o rings and gasket. Got all the dash  lights and even the cigarette lighter working. Tach drive cable is worn, put a decent used one and got tach working again. The dreaded front axle narrowing in is soon to come.
