KY2674
5088 rear axle housing
Any tricks to remove the rear axle housing? Is it better to leave the outside planetary ring on the tractor if that's possible. Ordered a service manual but hasn't arrived and would like to get the housing to the dealership to replace axle bearings. Thanks
2 hours ago, Thesd5488 said:
Pull bolts slide it off not bad to do
Thanks for the reply. Was trying to leave the outside ring gear and planetaries on the tractor but figured out because of the snap ring that's not possible .
Leave ring gear on axle, and I make sure the sun gear stays in the rear end.
